Repair Brake lights stay on
Old Nov 3, 2023 | 08:30 PM
  #26
Dave Elliott's Avatar
Dave Elliott
Hi,
Sorry for jumping on this old thread, but I thought it was better than starting a new one.
My 2006 MCS developed this issue recently.
Brake lights stuck on when ignition key is in position 0 or key is removed. Brake lights function normally otherwise.
My BCM looks dry and there has never been water or dampness in this area. The car has been garaged and not used much in the last year.
Wondering if anyone has found a definitive solution when there is no external diode.
Old Jun 5, 2024 | 04:45 PM
  #27
bugeye1031's Avatar
bugeye1031
Moderator
Did you ever find a solution?
Old Jul 6, 2024 | 02:39 PM
  #28
Yjsaabman's Avatar
Yjsaabman
Curious no one has found a solution on the LCI cars. Just went through this on our 2003 R53 Grumpy. I started with a switch because it was cheap, easy, and fairly common, but it did not fix the issue. Found the diode, it's wasted, even though we've never had water ingress issues with the car. I guess 212k miles has taken it's toll.
Does anyone know the purpose? Will it hurt anything to leave it out? I mean, I get that a diode basically works as a check valve only allowing electricity to "flow" one way. But does the circuit really need it? The lights work properly without the diode and I've seen other mentions to just bypass it.
Old Oct 21, 2024 | 03:39 PM
  #29
Apexlate's Avatar
Apexlate
Revive old thread
I have an 05 with no diode to repair/ replace. Any suggestions to fix this?
Old Oct 22, 2024 | 04:04 PM
  #30
Yjsaabman's Avatar
Yjsaabman
First thing check would be the brake light switch.
Old Dec 12, 2025 | 09:42 AM
  #31
manat's Avatar
manat
thank you very much for the very detailed diode replacement instructions and where to find a fitting diode replacement!!
zach999
Oct 5, 2020 07:27 PM
adude007
MINI Collectibles
19
Dec 21, 2018 12:45 PM
laforze
Jul 10, 2018 12:02 AM
jnathan68
Dec 26, 2014 12:59 PM
bmwproboi05
29
Dec 12, 2009 07:43 PM
