Loud Ticking Noise on Hard Acceleration
Old Aug 20, 2012 | 10:30 AM
coloradomini_s's Avatar
coloradomini_s
Hello All,
New here and was wondering if anyone can provide some assistance.
I picked up an '07 Cooper S less than a year ago and just recently noticed that on hard acceleration (mainly first gear) I would hear a loud ticking noise after about 3k RPM.
It will happen on 2nd gear but not as many ticks.
Car has about 50k miles on it.
Thanks for the help.
Old Aug 20, 2012 | 09:41 PM
bluefox280's Avatar
bluefox280
Checked for proper engine oil level?
Where is the tick coming from?
Does it occur only under load (accelerating in gear) or can you recreate the noise at a stand-still when rev'ing the engine?
Need more specific details to assist.
Where are you in Colorado?
- Erik
Old Aug 21, 2012 | 07:05 AM
coloradomini_s
Thanks for responding Erik.
Oil level is good.
Tick noise sounds like it is coming from the driver side.
yes, only occurs under acceleration. no noise when revving the engine at a stand-still.
Louder and more ticks while in first gear under hard acceleration and will also do it in second gear but not as loud and not as many ticks.
I am in the Thornton area.
- Erik
Old Aug 21, 2012 | 07:34 AM
laforze's Avatar
laforze
I think this is similar to the problem i'm having. Sometimes when i'm under hard acceleration, between approx. 3.2k - 4k there is a bog down as well as some rattling that happens. The rattling doesn't always occur, but it has more than once on this same occasion.
submitaweasel's Avatar
submitaweasel
Originally Posted by coloradomini_s
Hello All,
Are you using lower quality gas?
Old Aug 21, 2012 | 07:47 AM
bluefox280's Avatar
bluefox280
Ok, sounds like a drivetrain detail, and not nescessarily an engine issue.
I'm just on the other side of the highway; 136th + Zuni.
If interested, you're more than welcome to swing by and have me take a look at it.
Let me know; shoot me a private message.
- Erik
Old Aug 21, 2012 | 08:50 AM
coloradomini_s
laforze - thanks for a better description - more of a rattling.
submit - always put the highest octane that is available (91 in CO).
Erik - i will send you a pm - thanks!
Old Aug 21, 2012 | 09:00 AM
submitaweasel
Figured but I always try the simplest possible fix first
Old Aug 21, 2012 | 03:54 PM
fenderless 33's Avatar
fenderless 33
From the sound of what you are discribing you have a bad lifter, lift spring or have rolled cam shaft. I am not an expert on Mini engines but have built SBC with lots of HP and that is what it sounds like to me.
Old Aug 23, 2012 | 09:07 PM
coloradomini_s
So I went over and visited Erik - thank you Erik - and we tried to duplicate the noise but after driving for about 10 min trying to get the noise to come up, nothing.
The next couple of days I tried to duplicate the noise and still nothing.
Not sure what it could have been. We did notice that when we were looking in the engine bay that the fuse box was broken and was not seated.
Maybe that was it?
I will keep my ears open to see if this comes up again.
Thanks for the responses and thank you Erik for spending the time.
Old Nov 2, 2012 | 10:26 AM
laforze's Avatar
laforze
So i'm still having this issue. Again, if I get on the pedal between 2.8-4k the car will bog down at times and there will be a rattling that sounds like it's coming from the under carriage on the drivers side. The thing i just noticed the other day when this happened again, there was a puff of dark smoke that came out of the exhaust. Anyone know what this might indicate?
Old Nov 2, 2012 | 10:34 AM
submitaweasel
A puff of dark smoke indicates unburned fuel which would cause it to bog. Sounds like turbo issues to me.
Maybe carbon buildup on the intake valves? Not enough air not getting into the combustion chamber either way.
Old Nov 2, 2012 | 10:38 AM
laforze's Avatar
laforze
Thanks for the quick response! I'll look into this more.
Old Nov 2, 2012 | 10:43 AM
submitaweasel
I guess that was just good timing I just logged in Those are just my guesses based on what I've read here.
lweaver
Sep 17, 2024 08:22 AM
Colt45Magnus
Aug 27, 2024 05:03 AM
tylewis
Sep 6, 2015 01:07 PM
Sailorlite
Sep 4, 2015 07:03 PM
Sep 3, 2015 02:06 PM
