Belt tensioner replacement options - LUK?
I'm in need of a new belt tensioner for my '06 R53.
I've found a few options online...
penskeparts.com
OEM belt tensioner for $257 (at this time) - part # 11287509476
Google for the LUK belt tensioner
part # is BMW026221 - Cheapest I found was $93 (at this time)
Has anybody used the LUK brand tensioner?
I imagine the quality can't quite be up to OEM but I'm wondering if it's crap or not. I guess for an extra $20 it would be good to get the tensioner stop (Alta makes one) that would keep it from catastrophically failing. Installing that while replacing wouldn't be difficult.
penskeparts.com
This is what I did:
http://www.pelicanparts.com/cgi-bin/...2D%30%38%29%20
and then I bought and installed these too:
http://www.waymotorworks.com/powerfl...e-bushing.html
Works like a charm. And I also have an Alta tensioner stop.
I've bought three over the years from different sources. The Gates purchase online for $90 most recently. To be honest, when you line them up and study them, they are all made by the same manufacturer, just priced differently at outlets/sources.
Any thoughts about longevity of the brands? I got a Gates last year and it's bouncing already, even though the shock absorber looks identical to the OEM one I took off.
I'm considering this Alta rigid tensioner stop. Does anyone have any thoughts or experience on this one?
http://www.altaperformance.com/p/254
Have you tried the Litens brand? Not only is it cheaper, but the part is an exact replacement and they're an OEM supplier for BMW.
888.280.7799 | 6am - 5pm PST
I do not recommend using the alta tensioner rod. They call it a damper but it's the same as an adjustable end link. It does NO dampening. The tensioner was designed for a damper for a reason and you won't have the correct belt tension with a link that has no give.
We did make our own WMW delrin damper bushings due to the others we've seen fail.
Yeah, I understand. Just like the lousy OEM harmonic damper, what I'm wishing is for a more durable strut. Old school tensioners were manually adjustable & never seemed to harm anything long term. This shouldn't be like replacing a harmonic damper w/ a solid pulley. The only drawback is having to manually adjust when you get belt squeal or slip. Advantages? No fear of effects snapped belts, worn bushings,+ they're practically a cheap lifetime part.
Keep a close eye on the manual adjuster.
In the old days with V-Belts the adjustment was always manual, but I think it is easier to throw a serpentine belt since it doesn't ride deep in a V so I would check the tension very frequently.
ive also recently picked up one of the alta adjustable tensioner stops. going to be putting it in when i replace the crank pulley. i purchased the 2% overdrive ati super damper pulley. my main hope for this alta tensioner stop, is that this $425 pulley will be protected in the event of belt failure. im not sure what the negative effects of this alta tensioner stop will be, but if anyone cares to explain in a little bit of detail, id appreciate it. it seems like a decent idea to me as long as it is adjusted to the correct length.
Theoretically with the Alta Adjustable, you will need to initially calibrate an ideal constant applied tension, readjust 'periodically' to make sure you won't have squealing & slipping. This may not be ideal if you track your R53 as you'll be exposing the belt to a wide rev range. Generally & presumably, the Alta should be good for 'regular', less aggressive city/highway driving behavior. We don't have enough data to extract a realistic average adjustment interval yet. This thread below has some user reviews on it.
https://www.northamericanmotoring.co...testers-4.html
The Alta eliminates the need for a tensioner tool, but releasing tension won't be as convenient as the OEM & that tool. It also gives you peace of mind on the collateral damage from snapped belts. Neither would you have damper & bushings to replace anymore.
There are pros & cons to both, hence the 'controversy'. Long term tests shouldn't hurt, unlike the case of harmonic damper vs solid. Definitely we should go w/ the former on that.
I'm curious myself & would be a willing tester as soon as mine arrives. Alta site seems to have run outa stock. We'll see.
thank you minsanity. i understand now. i dont track my r53, but i do like to frequently pretend that highway on-ramps are 1/4 miles haha. i also just purchased that tensioner tool. i like the idea of being able to adjust the tension, but after reading all this, im a bit hesitant to put this thing on there. i guess i'm just guna have to do it and see what happens, like you said. i think for me, the big one that takes the cake, is that id rather replace a tensioner stop and a belt, than a $425 pulley. thanks again for the info.
minsanity. im in the process of installing my new crank pulley. ive got the old one off. the new one is ready to go on. i just installed the alta tensioner stop. i am now extremely confused as to how im going to move the tensioner assembly out of the way to fit the new crank pulley, since the oem tensioner tool seems to be useless. do i really have to unbolt the alta tensioner stop, raise the tensioner, and fit the pulley, and lower the tensioner, and re bolt the alta stop? or am i missing something?
Sorry to have missed your post jown. Just checked in. By now, you must've known that crank pulley is accessed by removing the passenger wheel well. How's the 17% S/C & 2% overdrive crank combo? Post dyno results should you get one, okay?
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
