Guys please help...what is this part?
Old Dec 21, 2011 | 01:15 AM
Rikay's Avatar
Rikay
it has been 2 weeks the dealer is ordering parts for me and cant get it right that what part is this....
its mini cooper s R53 6speed manual left hand side shaft...but what is at the end...its like an aluminum bearing or something that goes inside the gearbox
the DEALER even cannot figure it out...
please help...where can i can it?
i am attaching a picture for it...
Old Dec 21, 2011 | 01:51 AM
jpitchford's Avatar
jpitchford
I believe its just the axle seal. part number 23117550058
Old Dec 21, 2011 | 02:00 AM
Rikay's Avatar
Rikay
thanks for the reply bro but axle seal is HARD-PLASTIC this is something else, aluminum kind of bearing...here is another picture ...take a look
Old Dec 21, 2011 | 02:39 AM
HRM's Avatar
HRM
That is a seal, or looks like a seal. Was the car worked on before in that area? Why did you take it apart. If someone put an extra or wrong seal it make be a cause of the issue.
Old Dec 21, 2011 | 02:48 AM
Rikay's Avatar
Rikay
hello HRM...
it was leaking the transmission fluid from the driver side...took out the shaft and found this...
now i am thinking the car was worked before,a guy once fixed the leaking fluid from the transmission 2years ago and he used some replacement part
...the dealer says mini has nothing like this...
can it be axle seal part number 23117550058? Left hand side
Old Dec 21, 2011 | 02:49 AM
cmt52663's Avatar
cmt52663
is that not the output flange seal? Perhaps the plastic was upgraded at some point? If it is a bearing then I would expect roller bearings and a cage to seperate the inner and outer races, which does not appear to be the case...
Old Dec 21, 2011 | 02:53 AM
Rikay's Avatar
Rikay
flange seal bro?
is there an OEM part number for it...never heard of it....i see in minimania...looks really alike...
i think i am getting close
Old Dec 21, 2011 | 05:13 AM
jpitchford's Avatar
jpitchford
Chevy uses an axle seal similar to that on the 3/4 ton trucks. Its a sleeved seal. It presses into the case then onto the axle shaft. My bet is someone has replaced the OEM seal with that. Where they got it from or why they used it I can't tell you but if you replace it with the OEM seal I'd bet your leak would go away.
Old Dec 21, 2011 | 05:22 AM
Cobra-racer's Avatar
Cobra-racer
Ditto on sleeved seal. Used them on our transaxle shafts for our FA race car.
Old Dec 21, 2011 | 06:19 AM
mdsbrain's Avatar
mdsbrain
Does this help from realoem.com
http://www.realoem.com/bmw/showparts...23&fg=15&hl=10
Its #8 in the pic listed as Shaft seal.
Old Dec 21, 2011 | 12:00 PM
Rikay's Avatar
Rikay
THANK YOU ALOT GUYS for reading and answering to me...
it was number 8 like what mdsbrain and jpitchford... actually the mechanic who replaced this seal before used this silver thing to stop the leak and now it go bad and no one knew from where it came...
i will get back the mini tomorrow...all the parts are perfect...
Thank You jpitchford,msdbrain,HRM,Cobra-racer,cmt52663...you guys saved me from a headache that i have been having from 2weeks running to the dealer and here and there...
marendt428
Nov 14, 2015 10:03 AM
Minibeagle
Aug 13, 2015 10:00 AM
PrimePower
Aug 11, 2015 12:51 PM
marendt428
Aug 8, 2015 04:44 AM
eliseo1981
Aug 6, 2015 05:00 AM
