MINI out of warranty, check engine light on
Old Dec 15, 2011 | 04:24 PM
napria's Avatar
napria
Has anyone used a diagnostic code scanner with any success? My dealer is far away and I would rather find a local mechanic, but would like to be armed with knowledge going in.
Old Dec 15, 2011 | 04:31 PM
AXO's Avatar
AXO
I think autoparts discounts and pep boys will scan it for free. I would call first.
Old Dec 15, 2011 | 04:55 PM
Capt_bj's Avatar
Capt_bj
b4 you panic, the check engine lite is 99 times out of 100 an emissions issue
and that often turns out to be a failed oxygen sensor
so don't get your panties in a wad just yet . . .
YES, most major part stores will read a code for free . . . your dealer will probably charge you $75 or more . . . .
napria's Avatar
napria
Yes, there are a few who do check for free, but I've heard stories that confirm the adage that nothing in life is ever truly "free" so I'd rather do it myself then go in knowing what the problem is.
So... Anyone use a diagnostic scanner with any success? Any scanner recommendations?
Old Dec 15, 2011 | 05:00 PM
teamrubixcube's Avatar
teamrubixcube
I've been to an Autozone around the area with my old r50 and they truly scanned it and told me the code for free. It's worth a shot instead of paying $$ for a scan tool you'll likely not have to use again.
Old Dec 15, 2011 | 05:11 PM
napria's Avatar
napria
I dunno, we've got 2 MINIs and a Chevy dually... I wouldn't be surprised if a check engine light comes on again. We tend to keep our cars a long time. My husband's 325e was in the family for 16 years and he did most of the work on it himself after the warranty expired.
Old Dec 15, 2011 | 07:41 PM
jcauseyfd's Avatar
jcauseyfd
I think the perfect scan tool for you would be one of the models by Peake:
http://www.peakeresearch.com/
Old Dec 16, 2011 | 01:46 AM
HRM's Avatar
HRM
The scangauge is useful for monitoring things as well as scanning and resetting codes. Many many folks use them including me.
http://www.amazon.com/ScanGauge-Auto.../dp/B000AAMY86
When computers came into the auto industry folks (like me) figured it was going to be a nightmare to fix. Truth is mostly it makes things easier. Read the code, find out the widget needs replacing, buy a new one, then at worst you can just look around until you find the old one and replace it. In reality, using google, you can find out tutorials to replace it and lists of common issues, so the computer made it easier to fix cars in the end.
Old Dec 16, 2011 | 06:37 AM
cristo's Avatar
cristo
Alliance Member
I have the Peake tool and have used it successfully several times.
Old Dec 16, 2011 | 07:54 AM
Flyinace2000's Avatar
Flyinace2000
If you get the scan tool, might as well get the shop manual too!
Old Dec 16, 2011 | 08:07 AM
bluefox280's Avatar
bluefox280
Bavarian Technic scanner; it's dedicated to read all MINI / BMW prodigals and modules outside of the ECU (like ABS, airbags, etc, etc.):
* http://bavariantechnic.com/
- Erik
Old Dec 16, 2011 | 09:15 AM
strobeyprobey's Avatar
strobeyprobey
The Peak tool is NOT compatible with the 2nd gen Coopers R55/56/57/58/59/60 vehicles!!
Old Dec 16, 2011 | 09:20 AM
strobeyprobey
Finding a cheap GT1 with DISv57 would be what I would recommend.
Old Dec 16, 2011 | 10:11 AM
jcauseyfd's Avatar
jcauseyfd
Thanks for clarifying that strobey. I didn't really pay attention to that when I posted the link.
Old Dec 16, 2011 | 12:44 PM
napria's Avatar
napria
HRM, Thanks! I'm thinking we'll get the ScanGauge. I'm guessing we'll need the manual too?
Old Dec 17, 2011 | 05:25 AM
btor's Avatar
btor
You just plug it in and hit the scan mode. there tec suport is also great.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Dec 23, 2015 10:36 AM
Lt. Dan
Aug 10, 2015 08:23 AM
