R52 Rear Rubber Top Molding is Rotting Away....
Old May 16, 2014 | 07:50 PM
  #51
MEY mini's Avatar
MEY mini
Wow looks awesome!!! Glad u found it easy too, I also put my own stripes on recently too...
Old May 17, 2014 | 02:36 PM
  #52
Terryr's Avatar
Terryr
Replacement of convertable trim pieces.
Originally Posted by martinb
If you're talking about the 1st car, then no panels need to be removed. Simply unlatch the top (those two levers on either side of the rear hatch) and push the back of the top up. I used a piece of wood to hold it up and out of the way while I worked on the trim. Then all fasteners are exposed.
Thanks Martinb for your directions on the access to these screws, helped a lot. Bought these parts from ECS Tuning for $311 incl shipping. With your directions replaced these items in about 30 minutes Easy Pieasey.
I suppose it could be filed under "Its easy when you know how"
Regarding the cost, which is a bit much, I look at it regarding the damage this may cause if not replaced, leakage into the trunk area. If this happened the trim would HAVE to be replaced anyway, as well as any damage caused. Thanks for your assistance with information supplied. That's what these Forums are all about, helping each other with problems and resolutions.
Old May 18, 2014 | 11:57 AM
  #53
Duchess's Avatar
Duchess
Originally Posted by MEY mini
Duchess, did you replace the moulding trim? Let's see some pics
Hey, MEY mni, here are some pics.
Old May 19, 2014 | 06:25 AM
  #54
MEY mini's Avatar
MEY mini
Looks great Duchess!!! Thanks for the pics!
Old May 19, 2014 | 06:26 AM
  #55
Looks great, btw really like the Hot Orange.
Have you ever though of doing the chrome roll bars covers? Take the standard black ones off and snap in the chrome ones. 4 main pieces.
51437124905 , 51437124906 , 51437124907 , 51437124908
http://www.ecstuning.com/Search/SiteSearch/51437124905/
http://www.ecstuning.com/Search/SiteSearch/51437124906/
http://www.ecstuning.com/Search/SiteSearch/51437124907/
http://www.ecstuning.com/Search/SiteSearch/51437124908/
Old May 22, 2014 | 03:34 PM
  #56
patchelect's Avatar
patchelect
My car had those roll bar covers on it when I got it (used). Were they an available option when new? Somehow I don't think the 2 previous PO's added anything to the car that didn't come on it.
And hijacking the thread for another topic, has anyone done a DYI top replacement? I'm getting close to needing one but the entire job seems to be more than I can handle. I've changed tops on my Miata a few times, but that was a manual top and had no magic electronics or electric motors and pumps.
Old May 23, 2014 | 05:14 AM
  #57
Believe it was an option and came with the chrome line interior package. If they bought a less option/ loaded MINI, then most likely that how it came. Easy change though. If you need a factory top we have the parts. They came in Black, Green, and Blue. I know you will need the small install kit also for the top.
Old Nov 13, 2016 | 03:50 PM
  #58
jonk1969's Avatar
jonk1969
Originally Posted by Mini Mee
Do you have a diagram or pic of where these parts go?
Wish I'd known about ECS before I ordered my left and right molding pieces from another vendor. Paid about $375 including shipping, but it didn't include hardware or the two small foam side seal pieces above. Do those foam parts commonly wear badly, or get ruined when you remove the molding?
Old Nov 13, 2016 | 06:03 PM
  #59
Whine not Walnuts's Avatar
Whine not Walnuts
I just recently posted a simple repair in lieu of replacement. As IMO the upper rotted rubber does not impact the trim's ability to shed water, I don't think the foam inserts above would deteriorate as they are not subjected to ultraviolet. Perhaps others with more vert experience can chime in. Below is the link to my recent post and also are the pictures from the final product. Total cost, less than $20.
https://www.northamericanmotoring.co...p-options.html
Old Nov 13, 2016 | 06:09 PM
  #60
jonk1969's Avatar
jonk1969
Thanks, I appreciate it!
Old Nov 15, 2016 | 02:05 PM
  #61
Welcome, yea they don't get ruined like the outside, they get compressed a little. But they come with the new kit. And we have the hardware which on my MINI was all rusted and pretty bad.
Old Nov 15, 2016 | 02:14 PM
  #62
gsfent's Avatar
gsfent
Great solution! And if you blacked out the chrome, it would look OE.
Regards,
Jerry
Old Nov 15, 2016 | 02:30 PM
  #63
Whine not Walnuts
I'm looking for a peel n stick trim that has a flexible vinyl on it. I have found some pictures but would like to see the actual piece.
Old Jan 9, 2017 | 06:04 PM
  #64
burley's Avatar
burley
Old thread, new post..
Does the weather strip keep rain out?? Will water get in my boot without it? Just picked up an R52 and its rotted to hell. I'm afraid to drive it in the rain.
Old Jan 9, 2017 | 07:14 PM
  #65
Mini Mee's Avatar
Mini Mee
Nope
Old Jan 9, 2017 | 07:24 PM
  #66
burley's Avatar
burley
Nope
Wet stuff just drains through some other channel and out some hole? Sounds like a rust issue waiting to happen like below the tail lights.
Old Jan 10, 2017 | 05:58 AM
  #67
Yea, there is a channel in there and it suppose to drain out the back down the sides of the boot channel. There is a rubber seal that set in the corners. What I noticed on mine is with the new rubber seal the water trails over the seam where the top stitching can be seen and then goes down the side of the car. So it keeps more out of that channel gutter under the top. Also, my old trim on the bottom side was cutting into the paint a little over time as the plastic gut brittle. I had it repainted due to rust under those taillights, so its much better, but the old trim that's falling apart left marks towards the front of that trim where it meets the paint on both sides until the paint work fixed it and the new trim replaced. Great place to get rust over time I guess. If you open the trunk.
If you open the trunk like this and look on the bodywork shoulder ( rear quarter panel) near the trim at the top, if you have old trim you might have those rub marks.
Old Jan 10, 2017 | 02:27 PM
  #68
Whine not Walnuts
Just like the sunroof weeps, the vert rear gutters should also be cleaned out. The ECS picture is showing the weeps for the gutter below the bar stop light, there are two more, one on each side of the car.
I have noted that the bottom of the trim has rubbed the paint enough that it can be seen. I apply a sil-glyde type product on all the rubbers of the top including this trim twice a year (something I learned from having 7 other verts). It keeps the material more flexible and in this instance helps cut down the wear.
I put some painted black trim on (see link below to another post on this matter). Car was parked outside for the first two months until I sold my Vette, no water issues in that time.
https://www.northamericanmotoring.co...options-2.html
Old Jan 10, 2017 | 02:36 PM
  #69
Whine not Walnuts
And, one of the rattles that was driving me crazy was the rear gate emergency open. If you review this triangle shaped grasp lever, you will note that it sits on top of a peg that comes out of the plastic gate trim. I assume at one time there was some type of clip that held the handle in place as without the thing bounces around every time you go over any type of small bump. I used a plumber's faucet washer that pushes over the peg and holds the handle in place.
If you are getting vibe rattles in the back, check the under the car x braces that cross over the gas tank straps. I cut and put some rubber pads on the braces. Solved that rattle out.
Read some of my other posts where I show some other rattle points on the R52.
Old Sep 17, 2017 | 07:45 AM
  #70
Subw00er's Avatar
Subw00er
Did your rear trim align well where it meets the sides?
Thats not mine, but shows the area. mine is pushed more in and doesnt line up well
Old Sep 17, 2017 | 03:51 PM
  #71
Whine not Walnuts
Picture is not showing up.
Old Sep 17, 2017 | 06:53 PM
  #72
Subw00er's Avatar
Subw00er
Oops, fixed it.
I noticed some triangular plastic pieces near that joint underneath the trim. Mine didnt seem to move.. are they to assist in aligning the two trim pieces?
Old Sep 18, 2017 | 05:00 AM
  #73
Whine not Walnuts
Are you talking about the area in the below? If yours is not similar then would think something got bumped/banged out of place.
Old Sep 18, 2017 | 08:27 AM
  #74
Thats what it should look like with a that small gap. Check the trim and adjust if needed. Horizontally it should be straight.
Old Jul 20, 2018 | 05:24 AM
  #75
Whine not Walnuts
I am moving this thread into the R52 section. It is now well over a year and half since I did this inexpensive modification and there are no leaks associated with it and the painted trim has held up quite nicely as you can see by the pictures below. To recap:
1.) I trimmed off the rotted vinyl and applied a small bead of black silicone to cover up the stitches that are below the trim. IMO the trim did nothing but protect the stitches from UV rays. You might want to apply some blue painters tape just above the stitches so that you can minimize the silicone spread onto the top fabric.
2.) Once the silicone is dry, take a clean shop rag, dab some lacquer thinner on it and wipe the top of the black trim that remains after you have trimmed it. The material is gummy-like to start with.
3.) I bought some Cowles # S37750 1/2" chrome trim that you pick up at most autopart stores and painted it with a trim/bumper type semi-gloss back paint. I cut the pieces a little longer and hung them up so that I could paint them.
4.) Once the trim is dry you remove the double sided tape cover and slowly apply the painted trim to the old trim.
I have added blackout tape on the chrome beltline since I did this back in November of 2016.
