Clutch pedal problem
Old Sep 5, 2011 | 07:29 PM
mariocaz's Avatar
mariocaz
Hi guys,
I want to ask your help to find my problem....
The problem is that sometimes (mostly when the car is cold) when I push the clutch pedal to enter some velocity (anyone) it doesn´t come back and I can´t enter any other velocity, so I have to pull it in the back of the pedal with my foot to return it and then push it again to enter the velocity. And also is not doing this all the time, only sometimes as I mentioned it.
My mechanic told me that is the cylinder of the clutch, but he didn´t know if is the master or the slave cylinder, so I asked in the store and they told me that is the slave cylinder, I already bought it and I have it, only want to be very sure if that is correct, to go with my mechanic and change the slave cylinder.
Anybody has this same problem ???
Thanx a lot in advance!
Mario
Old Sep 6, 2011 | 06:59 AM
jhiggs26's Avatar
jhiggs26
There's a small return spring up in pedal box assembly. Make sure yours is located correctly.
Jeremy
Old Sep 6, 2011 | 08:17 AM
mariocaz's Avatar
mariocaz
jhiggs26, but that piece could be also if sometimes do it and sometimes don´t ?
Thank you a lot.
Old Sep 6, 2011 | 08:20 AM
Blackbomber's Avatar
Blackbomber
Even if the return spring is bad, the pedal should still return. The spring is just for the pedal, to allow the free play, and keep the throwout bearing off of the pressure plate once fully engaged, and foot off pedal. The pressure plate itself is what returns the pedal. Clutch hydraulics fail when a seal no longer does it's job, and air gets into system. If the slave were to fail, there is a likelyhood that fluid would also leak out. To check, pull back the rubber boot on slave, and see if it's filled with brake fluid. If so, your slave is definately bad. If not, I would suspect the master. When a master fails, there can be a leak, or not. Here in the US, where the parts are realatively cheap (my slave was $34.00 OEM from an online retailer), it's common practice to replace both as a pair. I was once told by a professional mechanic that a new slave can stress the old master, vice/versa, when I had one go shortly after the other. I don't know if I believe that, but I'm offering it as food for thought.
Old Sep 6, 2011 | 09:21 AM
mariocaz's Avatar
mariocaz
Hi Blackbomber,
So the most possible thing is that the slave is bad, right ??, but the most common is to replace slave and master ??, I bought the slave in US in that price, I have a shipping address at CA.
But maybe change the slave in a short time I will have to change the master ?
Thanx again.
Old Sep 12, 2011 | 10:31 AM
Disco's Avatar
Disco
It may sound really bizarre but I had similar problem before and it turned out to be the pedal stuck under the floormat.
Old Sep 12, 2011 | 10:34 AM
mariocaz's Avatar
mariocaz
Hehehehe my problem is not that, I wish it, but thanx for tell me.
Does somebody know if the slave cylinder is the one that is in the pedal ?? or that one is the mastery cylinder clutch ?
Thanx again guys!!!
Old Sep 12, 2011 | 08:30 PM
mariocaz's Avatar
mariocaz
Help to know this!!!
Old Sep 18, 2011 | 04:27 PM
DaveVT02S's Avatar
DaveVT02S
The clutch slave cylinder (MINI calls it the "Output Cylinder Clutch") is the one located on the lower front of the transaxle...
Old Sep 19, 2011 | 04:59 PM
gawannamini's Avatar
gawannamini
Originally Posted by DaveVT02S
The clutch slave cylinder (MINI calls it the "Output Cylinder CLutch") is the one located on the lower front of the transaxle...
+1
Master connected to pedal. Slave at clutch/transmission end.
Old Sep 19, 2011 | 05:07 PM
mariocaz's Avatar
mariocaz
Thanx so much for all your nice help, the problem with my Mini was the slave cylinder, so my mechanic changed it and now my Mini is again fine, I am very happy!!!
Thanx a lot!!
Camaro108
Aug 25, 2015 02:44 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
cornfly888
Aug 24, 2015 09:57 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
