who has used this pully puller and do you like it?
Old Jan 20, 2004 | 01:15 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
has anyone used this puller from out motoring?
http://outmotoring.com/supercharger_...oval_tool.html
did it work well for you?
is it a two part puller and does it bolt together on the pully?
how do you like it?
worth the $$$?
any info you can give me would be great. thanks. chad
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jan 20, 2004 | 04:19 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
My only concern would be that the two halves arent clamped together except by the screws holding it to the puller itself. Other than that, it looks like it would work fine.
Methinks I need to guinea pig this setup on my car...
_________________
"Earl Grey" - '03 MCS, DS over DS, 17" R85s, NAV, DSC (often turned off!), Packs #1 and #3, Rally lights, etc, etc. Perf Mods by the boatload, on the way! Fulton, MD. FRS 7-21
Let's Get Small!
Old Jan 20, 2004 | 06:10 PM
Detroit Tuned
Vendor - 15 Years
i thought the same thing. if i get it i will make two bolts that hold it together. still undecided yert. anyone else?
Old Jan 21, 2004 | 12:29 PM
Griswoia's Avatar
Griswoia
If you order the mini-maddnes or mania (can't remember which) you get this with the pulley, as one kit. It worked fine for me and is more that sufficently strong to do the job. Mine is aluminum with two robust bolts securing one side to the other.
Here is the link:
http://www.mini-madness.com/index.as...&ProdID=10
It's a good kit that is VERY easy to use, and the puller is reuasable as all get out. You could travel around the country and do the job with the tool.
The fact of the matter is that the pully is not pressed on with all that much torque.
Ian
Old Jan 21, 2004 | 12:35 PM
Detroit Tuned
Vendor - 15 Years
that one is nice, but i have a lead on a much cheaper cost for the other one and will be buying another pully anyways, but i would like to have a tool arount to install other ones. that is why i wanted to see who has used it. thanks anyways
Old Jan 21, 2004 | 04:34 PM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
I was following this thread and noticed the confusion in interpreting how the pulley puller that we sell works. I just reshot the product to better show how it works, which should clarify things.
It's a great product, in fact we can hardly keep them in stock!!!
http://outmotoring.com/supercharger_...moval_tool.htm
Old Jan 21, 2004 | 05:20 PM
2Cool's Avatar
2Cool
I just used Outmotoring's puller tool last night. It has two hefty allen head bolts that hold it together tight on the pulley. It worked fine, not slipping a bit despite my pulley taking about 4 minutes of continuous impact due to unexpected tightness on the shaft.
Old Jan 21, 2004 | 06:56 PM
Detroit Tuned
Vendor - 15 Years
thanks out motoring. that new photo really helps show what i wanted to know. a good photo or few really goes a long way. i will now look into buying the one i have a lead on.
p.s. you are missing the L on the end of html . it took mew a min. to figure out what was going on..lol thanks again
Old Jan 21, 2004 | 11:44 PM
The_Beastmaster's Avatar
The_Beastmaster
I've seen Eric Savage from Helix use a puller like that and he had the pulley off the car in minutes! Of course, this was after removing the airbox, ECU and undoing the motor mount.
_________________
The_Kid
Nov 3, 2016 06:30 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
yukinoinu
11
Sep 25, 2015 09:48 AM
yukinoinu
Sep 21, 2015 10:43 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
