Have to wait 20 secs before turn key!!!
Hi, I have an 06 base model. I had to rebuild the starter 2 years ago b/c of a short due to thermostat housing leak. about 6 mos ago the car started to not want to start on the first turn. I have to place the key into position II and I have to wait until all lights and beeps stop before I can turn the key the whole way. Then it starts. If I forget and turn the key all the way right away there is some clicks but no turn. Once in a while it works right away. I also have to completely shut off the keys before trying the second time. Can it be an eletronic problem, a starter problem or a solenoid? Thanks in advance.
It sort of does sound like a bad battery to me. When first switched on the self checks take too much juice to start it, then once the fuel pump gets pressure and everything goes dormant again, there is just enough juice to turn it over.
I had my wife turn the key and I had the hood opened. When she turned the key the starter kicked in but nothing happened. Maybe its not engaging the flywheel. I think Im gonna have the starter replaced. By the way I am very limited in mechanics.
Have the battery checked out first.....don't waste money on the starter. MINI's are very temperamental cars in regards to their batteries. Best way to check is to hook up some jumper cables and see what happens.
Thanks for all the help!!!! Tested the battery today and it was bad. So here we go to the third battery in less than 5 yrs. $130 for the battery, does that sound right??? Once again, thanks and sorry for the delay!!!!
3rd battery in 5 years, the first one came w/ the car, the second was replaced under warranty! The one I got today was the only one they had at the nearest auto parts.
You should not go through batteries that quickly, even if they are low quality. I would guess that there is some problem in your electrical system, perhaps draining the battery even when the car is off.
Sorry, I read your post wrong. But even 3 batteries in 5 years is a problem. I'd have a mechanic look into it.
From: So far south in AL, one more step and I'm swimming (in oil)
Don't forget to have them check your charging system as well. An alternator that is not charging the battery fully will kill a battery also.
polotska
Aug 23, 2015 03:03 PM
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
Aug 22, 2015 07:13 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
