Cold Weather Symptoms
Old Jan 16, 2004 | 05:46 AM
PMC's Avatar
PMC
Despite the grip of the polar air that has assaluted the Northeast, my MCS (D.B.- in honor of ... well, you do the research if you're too old to remember the legend of D.B. Cooper) has been running fine, but is making some squeaking noises in the rear suspension/body areas. I have H-Sport springs and tubular rear sway bar.
Anyone else experiencing anything like this.
Old Jan 16, 2004 | 05:51 AM
iamwiz82's Avatar
iamwiz82
I have a slight creaking as well, along with what sounds like the belt squeeling on start up when the temp is really cold. Plus, the OBC display has issues refreshing in these kind of temps
Old Jan 16, 2004 | 05:54 AM
chrisneal's Avatar
chrisneal
I've got a similar thing going on, although it seems only to happen while I'm on the accelerator. I'm taking the car in Saturday to see if anything's up.
Old Jan 16, 2004 | 06:50 AM
mcs22004's Avatar
mcs22004
No problems. Even the door handle cable hasn't snapped again yet. Plus the car starts. Sometimes the window drops properly when I open the door. No belt squeaks yet.
Old Jan 16, 2004 | 09:49 AM
Bisch's Avatar
Bisch
Yeah, I'm hearing all sorts of groans and pops in agony too. It barely cranked this morning at -1 degrees. The heater fan was "on" from last night, WOW what a squealing howl it made when I started the car! I get some thuds from the suspension as well. It sounds like someone hitting the wheels with a mallet.
I enjoy the cold, but this is rediculous! :evil:
There is just no need for temps like this...
I moved to Cape Cod expecting relatively mild winters yeah right!
Old Jan 16, 2004 | 09:54 AM
greatgro's Avatar
greatgro
Where were you moving from?...the Arctic Circle?
Old Jan 17, 2004 | 12:03 PM
Welker's Avatar
Welker
It's likely your swaybar bushings. I had this exact same peoblem.
The lube supplied with the swaybar tends to freeze at low temps, so I got some grease from Energy Suspension that is aupposed to stay gooey down to -80 degrees C, or something like that. Either way, it works.
Old Jan 17, 2004 | 12:11 PM
d-mini-ero's Avatar
d-mini-ero
https://www.northamericanmotoring.co...c=21479&25
Take a look at this thread.
I had a bad squeak ..that turned out to be the rear sway bar.
I loosened the sway bar...re-greased the bushings... and it's been fine... so far :smile:
Peace,
D
_________________
PM d-mini-ero
I own a 2002 MCS w/ alot of stuff on it.
ryGuyMCS
Oct 6, 2015 12:04 PM
Vaderm34
Sep 27, 2015 09:25 PM
shorenetworks
Sep 20, 2015 08:46 AM
Dedit Deus
Sep 17, 2015 06:11 AM
atlantaorange
Sep 16, 2015 12:43 PM
