Can anyone confirm if I have mushrooming or not?
Old Mar 21, 2011 | 06:12 PM
ThreeD's Avatar
ThreeD
This is an '05 Mini S. I've been doing research since I'm new to the Mini community and need those who have experience with this defect to chime in , please. If it is mushrooming, I know what I have to do. Thanks.
Old Mar 21, 2011 | 07:07 PM
HRM's Avatar
HRM
Hard to say, but it looks like it... All those bolts should be parallel. The metal under it started life perfectly flat, so the top should be too.
The fisheye effect of the lens makes it hard to be sure from here.
Old Mar 21, 2011 | 07:13 PM
ThreeD's Avatar
ThreeD
Hmmm, well I can tell you that there is sloping on both tops. It looked normal to me at first, but after reading that the bolts should be parallel, i can say they aren't 100%. The sloping isn't drastic, though.
Old Mar 21, 2011 | 07:22 PM
HRM's Avatar
HRM
This is what is under the tower from the factory. Others are the same. Flat with all bolts parallel.
http://www.waymotorworks.com/oem-fro...rut-mount.html
BTW, if you ever replace them, get these for $3.00 more...they add a bit of camber which is nice on the mini.
http://www.waymotorworks.com/ireland...e-r50-r53.html
Old Mar 21, 2011 | 07:27 PM
ThreeD's Avatar
ThreeD
Excellent. Thanks a lot. I have my work cut out.
Old Mar 21, 2011 | 11:33 PM
Eric_Rowland's Avatar
Eric_Rowland
They do look a bit 'shroomed. I got some STDs and gave the towers a few whacks until the STDs lay flush. My passenger tower was obvious; the driver's side not obvious until I put the STD over it. Also, check out the VIP product, it looks good and has a unique sleeved nut that allows full thread contact.
Old Mar 22, 2011 | 03:24 AM
ThreeD's Avatar
ThreeD
Silly question, but in order to hammer the tops back into form, the struts/shocks must be removed, right?
Old Mar 22, 2011 | 01:09 PM
Eric_Rowland
Not a silly question. No, no need to remove the struts - just put a 2x4 over the top of the mount and give it a few whacks. Note that placing a rag in between will help stop paint transfer to the 2x4.
Old Mar 22, 2011 | 01:21 PM
J_Westy's Avatar
J_Westy
I was also advised to jack that wheel up off the ground... seems like a good idea - no?
Old Mar 22, 2011 | 01:25 PM
Eric_Rowland
Couldn't hurt, but not really necessary. Personally, I'd rather have the force be supported by the wheel than whacking it while up on a jack.
Old Mar 22, 2011 | 04:11 PM
ThreeD's Avatar
ThreeD
Ok. Great. Thanks guys. I looked again and the "mushrooming" isn't all that bad as far as i can see.
Old Mar 22, 2011 | 05:56 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Wow, that is pretty bad mushrooming. You need to fix that. Replace the strut mounts and bent the towers back. Then you can either install some strut plates, or camber plates to keep it from happening again.
Old Mar 22, 2011 | 06:23 PM
ThreeD's Avatar
ThreeD
Hmm. You think so? In person it doesn't look that bad. Perhaps its my iPhone? But I take your opinion very seriously. When I take my car in for servicing next week I will pick the mechanic's brain.
Old Mar 22, 2011 | 06:24 PM
J_Westy's Avatar
J_Westy
Is that as bad as it looks... or is it the camera?
Old Mar 22, 2011 | 06:39 PM
ThreeD's Avatar
ThreeD
Honestly, it looks pretty flat in the flesh.
Old Mar 23, 2011 | 12:20 PM
ThreeD's Avatar
ThreeD
Lesson learned....This used Mini I just bought needs over $3000 in repairs.
The dealer who sold me the car is paying for the parts.
The list is so long it's not even funny.
Repairs:
Oil and filter change
Replacement of both strut tops as they are domed and mushroomed
Replacement of engine fan stage 1 as it is inop
Replacement of water pump as it was leaking
Both control arm bushings are c racked and replacing
Right muffler hanger is broken and replacing
Perform alignment for suspension work
Old Mar 23, 2011 | 01:43 PM
beken's Avatar
beken
I would suspect the MINI you bought was not well looked after. Since it is difficult to drive a MINI "carefully", I would expect to check over the car carefully (any used car actually) with a fine tooth comb before committing to buying.
Alignment and oil change probably should have been performed by the dealer before he sold it to you. The rest, if you bought your car CPO, should have been covered by the warranty.
The passenger side tower does look mushroomed. The driver side, not so much. I thought my towers were mushroomed, but when the plates were added, they sat flat. Go with non-runflat tires and that should prolong your front suspension too.
Old Mar 23, 2011 | 01:51 PM
ThreeD's Avatar
ThreeD
I'm in the process of ordering Conti All-seasons now. The car is not CPO. I admit, I purchased the car in haste. Long story. The car was under ownership of one person for the bulk of the time, so I don't know how so much went wrong when warranty would cover all that is currently wrong. I'm getting the entire car redone from head-to-toe and I'll consider it new, relieving me of stress for a while. Lesson learned....
Old Mar 23, 2011 | 01:59 PM
beken's Avatar
beken
The R53 MINI is really a very good car. However, it is built to very tight tolerances and once something goes wrong, a lot can go wrong. Driven within its limits (a very difficult thing to do), the car can be very reliable. My MINI has been more reliable than a Toyota Corolla I had many years ago. However, it is so much fun to drive, I have this saying that "it begs to be flogged".
Good luck and hope to see you at one of the national events in the future. I'll be waving at you.
Old Mar 23, 2011 | 02:04 PM
ThreeD's Avatar
ThreeD
After she's on the road again, I'll keep it for ever.
Old Mar 23, 2011 | 06:07 PM
J_Westy's Avatar
J_Westy
Do you have to spring for labor?
Old Mar 23, 2011 | 06:14 PM
ThreeD's Avatar
ThreeD
Yup and the labor costs more. Nice.
Alpha Motoring
Sep 7, 2020 07:34 PM
Filmy
Jun 28, 2016 08:58 AM
Mazarin
Electrical
Dec 7, 2015 08:23 AM
rt808
Sep 29, 2015 03:15 PM
jennster
Sep 28, 2015 06:19 PM
