fixed air bags / shop ran car outofgas,now won't start!
Old Jan 13, 2011 | 04:24 PM
JPMM's Avatar
JPMM
A month ago I slide on some ice, hit a curb , popping some air bags. got the car fixed local ($$$$) Trucked the car to Chicago and back to reset the air bag module (10 minute job). The local shop/trucker/ Patricks ran the car out of gas and/or drained the battery down, Back in Clinton IA the shop realized the lack of gas ,poured some in, now the car won’t start. Hope its just a flooded engine after cranking with a low battery. But it did crank? Tomorrow after sitting on a charger drying out I hope it fixes itself . Is there anything else I should look for? Fuses are OK. I am soo bummed. MINI needs more dealers (or allow BMW dealers to work on safety systems)
Old Jan 13, 2011 | 06:11 PM
liquid wrench's Avatar
liquid wrench
that stinks We have the same problem hear with lack of dealer knowledge.
Old Jan 13, 2011 | 08:04 PM
Vollgas's Avatar
Vollgas
Usually when a FI car runs out of gas, the FI system needs to be purged.
I'm not sure if Mini has this ability or not.
At least it's a starting point to check out.
Old Jan 13, 2011 | 08:23 PM
MaxGSeeker's Avatar
MaxGSeeker
You may need a new fuel pump. If not now then later since running dry on on older pump will usually lead to near term failure.
Old Jan 14, 2011 | 03:04 AM
JPMM's Avatar
JPMM
I can hear the pump run then pump up and stop before I try to start it
Old Jan 14, 2011 | 07:49 AM
JPMM's Avatar
JPMM
I can't find any info on Mini fuel system purges
Old Jan 15, 2011 | 09:06 PM
steve20607's Avatar
steve20607
Not sure about the MINI but some cars have a "reset" button in case of accidents to prevent more fuel from being sent thru and causing an engine fire.
Since your fuses are all good, I'd suspect some kind of reset switch or button if that's the case just don't know where it'd be located.
Old Jan 16, 2011 | 06:36 AM
JPMM's Avatar
JPMM
no button reset needed because I drove the car after the bags blew after we waited about an hour, (wouldn't start at first but the car reset itself)then they continued to drive the car around while being fixed until they ran it out of gas.
Old Jan 17, 2011 | 04:36 PM
rhcp4life's Avatar
rhcp4life
Having the same issue. I left my car out on the street went to start it the next morning, and it would not "pop" it would turn over but it just would not start.
But i have a full tank and i just filled up before i parked my car for the night.
Old Jan 17, 2011 | 05:14 PM
JPMM's Avatar
JPMM
well that just blows, wanna hitch a ride on the truck going to Chicago?
Old Jan 18, 2011 | 07:46 AM
JPMM's Avatar
JPMM
where did you get the gasoline?
Old Jan 18, 2011 | 10:24 AM
rhcp4life's Avatar
rhcp4life
kwik star,
Isn't there a new dealer and service station in Iowa? i believe its Des Moines
And i bought a Bentley manual, I'm going to see if i can fix it.
Old Jan 18, 2011 | 11:45 AM
JPMM's Avatar
JPMM
We went to Willis in Des Moines Sat , very nice. But the bodyshop has used Patrick Mini for all the parts and service so far ,so we needed to continue that way, for the insurance bills . Good luck ,it shouldn't be too much.My car could have accident related issues and I shouldn't try anything on it until its sorted out.
Old Jan 18, 2011 | 04:57 PM
JPMM's Avatar
JPMM
kwik star,
did you read this?
https://www.northamericanmotoring.co...e-battery.html
Old Jan 18, 2011 | 11:37 PM
steve20607's Avatar
steve20607
If it's not your clutch neutral switch, then try re-pressurizing your fuel line....check out the DYI thread on "fuel filter replacement", it's better explained there.
G/L
Old Jan 21, 2011 | 06:49 AM
JPMM's Avatar
JPMM
my car's running
what happened? as far as I know;
Ran out of gas, ran battery down, put in some gas, flooded engine, fouled plugs, burned up starter
getting the gasy oil changed, hope they won't screw that up
09R56
Nov 16, 2022 10:49 AM
bneer
Jul 15, 2019 04:41 PM
bc219
Aug 10, 2015 11:22 AM
tippin
Aug 5, 2015 08:43 AM
