395 for an injector?
I had a leaky JCW injector and was quoted $250 in Baltimore/DC area
You can do it yourself for a lot less. It now takes me about an hour to change all 4 injectors on my R53 with simple tools.
And you can pick up some used stock 340cc injectors VERY inexpensively.
I don't know what they charge for a brand new regular 340cc injector but the 380cc JCW's are $105 a piece from the dealer around here.
The quote you got is too high if that is indeed all they are doing.
I'd be happy to advise you if you choose to do it yourself.
Thanks! would have loved to do it myself, but time unfortunately is very limited at the moment. I should probably just consider getting the used injector and have them charge me for the labor which they said would be about 190, I hope this would atleast make it more reasonable.
I honestly don't know for certain. I think so though. The only injector change that I am aware of was done late in '06.
I wish you luck.
thanks so much guys, I really appreciate the much needed feedback. The thing is I had planned on getting jcw injectors next summer and do a tune at the same time, thats why I was trying to go real economic at the moment, tuition's taking up every penny I have.
It is about an hours job on a cold motor....
Add parts cost...
Used standard S injectors are pretty cheap...buy a full set, have extra's!!
All S's has the same injectors, as did all JCW cars until the JCW 210 kit came out in 2005..those are the blue striped 380's folks upgrade to!!
Just use new o-rings when you install used injectors!!
Add parts cost...
A full set of JCW 380's can be had for about $300!!
If you want a tune (you will need one with the big ones), you can get new undrilled bosh 550's on special from one tuner for like $250..for a set!!!
IQRaceworks
53
Jun 28, 2024 07:29 AM
dutchhome
Sep 30, 2015 07:17 AM
