Whats the deal with Inspection II?
Old Sep 9, 2010 | 02:50 PM
iwashmycar's Avatar
iwashmycar
Im just about to the 45K mark, and its warning me to go in soon
From looking over the usual items BESIDES CHECKING EVERYTHING (mostly visually), It comes down to air filters and brake fluid change (every 2 years).
I dont really care about the air filters / oil / brakes, and I can definately take care of a brake bleed on my own. Same with fuel filter, and coolant (though I didnt see it in the text or when to replace)
It also mentions they check for rust, and if I dont go in I surely do not want to jeopardize my rust warranty in any way.
So question is, should I take 'er in just so they can visually look at it!?.. Am i going to have to pay if they dont replace anything??
I guess I'll call regardless, but sometimes the MA's dont really know, so i'm looking for input, and mainly experience... I know a few are there / past 45K.
Old Sep 9, 2010 | 02:53 PM
iwashmycar's Avatar
iwashmycar
Found this but im pretty sure is First Gen:
[FONT='Verdana','sans-serif']MINI Inspection II:[/FONT][FONT='Verdana','sans-serif']
Undercarriage
Change oil and oil filter while engine is at operating temperature.
We recommend MINI Synthetic Motor Oil, p/n 07 51 0 143 829
Check transmission for leaks.
Change CVT (automatic) transmission fluid.
Half shafts: Check for leaks at flexible boots.
Visually check fuel tank, lines and connections for leaks.
Check condition, position, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks. Check p/s fluid level; add fluid if necessary.
Check overall thickness of front and rear disc brake pads (outer pads only) using special tool.
If replacement is necessary:
Examine brake disc surfaces. clean brake pad contact points in calipers. Grease wheel centering hubs.
Check thickness of parking brake linings only when replacing rear pads.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc.
Check brake system connections and lines for leaks, damage, and incorrect positioning.
Check parking brake actuation. Adjust if necessary.
Check all tire pressures (including spare). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern; in case of uneven tread wear readjust wheel alignment if requested.*
Note:If requested rotate all four road wheels as instructed and rebalance.*
Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years).
Engine Compartment
Read out diagnostic system.
Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary.
Note:Coolant must be replaced every 4 years (time interval begins from vehicle's production date).
Check level of brake fluid in reservoir. Add fluid if required.
Replace brake fluid every 2 years (timing interval begins from vehicle's production date).*
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner operation.
Replace microfilter.
Note: reduce replacement interval in dusty operating conditions.
Reset Service Interval Indicator.
Replace intake air cleaner element.
Note: Reduce replace interval in dusty operating conditions.
Replace poly V-belt.
Body/Electrical Equipment
Check battery state-of-charge, and charge if required.*
Check lighting system, i.e., headlights, foglights, parking, back-up, license plate, interior, glove box, illuminated make-up mirrors, luggage area lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check windshield and tailgate wipers and washer systems; wiper blades, washer jet positions.
Check condition and function of safety belts.
Check central locking system.
Check operation of all latches.
Check heater/air conditioner blower fan, rear window defogger.
Check rear view mirrors.
Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories.
Final Inspection
Road test with check of brakes, suspension, steering, automatic transmission.
Visually check shock absorbers for leaks.
[/FONT]
Old Sep 9, 2010 | 03:32 PM
Capt_bj's Avatar
Capt_bj
yes - you are correct - they are going to charge you a zillion dollars to visually inspect your car.
I let them do the pre-pay maint' then do my own oil changes and brakes and fluids 'til around 100,000 miles then sell the beast. If you find a warranty issue that is a different gremlin and I'd run to the dealer ... but on my 02 and up to now on the 7 .. Had some issues I TRIED to get them to cover but Noooooo.
I just ran out of pre-pay maint on the 7 while the service counter says I have 1200 miles to go for service one. Ya, like I'll take it in for that! (I'm a low mile driver now . . . ain't early retirement great?) I know how to reset the counter . . .
Old Sep 9, 2010 | 06:45 PM
iwashmycar's Avatar
iwashmycar
thought so.
ill just reset the counter after my personal 46K oil / brake fluid / rotation . ect.
Old Sep 9, 2010 | 08:48 PM
minitech829's Avatar
minitech829
i think the serpentine belt is maybe the only thing that alot of people might not want to try on their own.
Old Sep 10, 2010 | 01:03 AM
Oxybluecoop's Avatar
Oxybluecoop
The serpentine belt is a 10 minute job at most(pull the headlight,bridge and liner and your good to go). Call me OC but when inspection II popped up at around 45k I replaced the belt,oil,fuel filter,coolant,plugs,bled the brakes and seafoamed followed by a compression check. I'm now at 115k with not so much as a hiccup from this motor and that's with a PnP head and tune on an N12
Old Sep 10, 2010 | 06:05 AM
iwashmycar's Avatar
iwashmycar
Good to hear. Id definately like to do all the above.
Did you use MINI fluids (brake/coolant), belt, plugs, and fuel filter??
Im sure there are better (at least brake) fluids out there.
Old Sep 14, 2010 | 07:50 AM
iwashmycar's Avatar
iwashmycar
bump..
Anyone else do thier own Inspection II??
Anymore suggestions on brands for replacement crap?...all OEM?
Old Sep 15, 2010 | 07:21 AM
strobeyprobey's Avatar
strobeyprobey
Personally, I would use all MINI (BMW) products for the fluids (especially the coolant, but I don't think you are due for that yet), brake fluid ATE, Oil there is a lot of debate but your safest choice is MINI oil (not really more expenisve), runner up Mobile1 0W-40 (European Formula). For filters and such, you can find the part numbers on RealOEM.com and order the parts from a bunch of online sellers of BMW Group parts, my recent favorite is parts.com as they seem to have the cheapest prices. You can get the oil filter kits and all the filters, and any other part.
Old Sep 15, 2010 | 08:23 AM
iwashmycar's Avatar
iwashmycar
Excellent. thanks for the info. Heard good about the ATE super blue fluid, so thats on the list, and Ive been using the Mobile1 for a while now. Good call on the filters, as I dont want to visit the dealer for those lol
Old Sep 15, 2010 | 11:12 AM
strobeyprobey
http://www.realoem.com/bmw/showparts...29&hg=11&fg=30
Oil filter kit 11427557012
http://www.realoem.com/bmw/showparts...17&hg=11&fg=18
Engine Belt (up to 1/2010) 11287566789
http://www.realoem.com/bmw/showparts...00&hg=13&fg=20
Non-Turbo Air filter 13717561235
http://www.realoem.com/bmw/showparts...=64&fg=10&hl=2
Activated Carbon Cabin Filter 64319127516
Old Sep 15, 2010 | 11:25 AM
iwashmycar's Avatar
iwashmycar
Fuel filter: 11252754870
S air filter: 13717568728
Belt: same as above
Oil filter: same as above
Plugs: 12120035531 (NGK ILZKBR7A-8G)
Wipers: 61610028137 (front) 61622754285 (rear)
Old Sep 15, 2010 | 02:03 PM
strobeyprobey
Ah yes, I should have check the turbo pages, my bookmarks are all the base model, sorry.
Also, the microfilter that is standard for the non-auto ac is non-carbon model:
64319127515
Old Sep 15, 2010 | 04:32 PM
iwashmycar's Avatar
iwashmycar
nice. might as well just build up a nice database of stuff here for others to search lol.
with a fuel filter, oil filter, 4 plugs, a belt and some new blades im up to about 150 bucks... beats the dealer any day
Old Sep 16, 2010 | 07:46 AM
strobeyprobey
It sure does! The dealer wanted to charge $200 to replace the microfilter for a BMW 6 series!!! So I just got the parts (needed two of them), for $60. I just did the water pump & thermostat on my Z3, saved a fortune by getting the BMW parts ($70 and $50) and doing it myself (with the help of forums and the shop manual).
Old Sep 16, 2010 | 08:23 AM
MCS Fever's Avatar
MCS Fever
Hears what I have gleaned for a maintenance schedule and dealer charges (or incentives to do it yourself) in the Seattle area:
Oil Change 1 Year or CBS
Micro-Filter 2 years
Brake Fluid 2 Years or CBS
Air Filter 2 Years or every 2nd oil change or CBS
Tires 6 Years
Spark Plugs 60K
Transmission Service 100K
Oxygen Sensor 120K
Coolant "..long term rating as does not need to be changed except for system repairs".
V-Belt N/S
Fuel Filter N/S
Power Steering Fluid N/S
1) Oil Change ($95)
2) Micro Filter ($90)
3) Transmission Service ($300)
4) Brake Fluid ($90)
5) Coolant ($150)
6) Air Filter ($80)
7) V-Belt ($180)
Old Jan 28, 2011 | 09:52 AM
coop922's Avatar
coop922
reset the cbs
how to reset the cbs on a 2009 coop
Old Jan 28, 2011 | 10:00 AM
strobeyprobey
Lifted from a BMW forum post: 1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car. 2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon. 3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu). 4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window. 5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on. 6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear. 7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above). Hints & Tips Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears. If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Old Jan 28, 2011 | 10:35 AM
coop922's Avatar
coop922
cbs
thank you very much strobeyprobey
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
gknorr
Dec 26, 2016 09:38 AM
vulkandino
Oct 31, 2015 08:29 PM
vetsvette
Oct 11, 2015 06:05 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
