Belt tensioner tool alternate?
Old May 3, 2010 | 09:55 AM
Neufusion's Avatar
Neufusion
In replacing the supercharger belt, do I need to use the offical MINI/BMW belt tensioner tool? Or will an alternate belt tool work as well?
http://www.turnermotorsport.com/html...ID=90880118410
http://www.summitracing.com/parts/SUM-900035/?rtype=10
Old May 3, 2010 | 11:40 AM
Eric_Rowland's Avatar
Eric_Rowland
The first one is OEM style. Not sure how the second would work. If you're cheap, you can just use a pry bar with a socket on one of the tensioner nuts for leverage.
Old May 3, 2010 | 02:36 PM
ZippyNH's Avatar
ZippyNH
The oem style tool makes it easy....it takes a ton of force...so watch you fingers if you use alternate methods...I don't think the universal one will work....but the abouve suggestion might...the socket as a fulcrum, then a prybar.....you would need a second set of hands to put a pin in the tensioner to lock it....if you have a pulley, you should change your belt yearly IMO, so find a mini club, and borrow the tool, or buy one...what you save on labor the first time you diy it, it pays for it self.
Old May 12, 2010 | 01:18 PM
ghurm001's Avatar
ghurm001
let me preface this with:
DON'T FREAKING DO THIS!
that said...
when i changed my a/c compressor out... i used a long *** screwdriver, precariously perched on top of a hydraulic jack to push up on the tensioner arm from the bottom. once or twice during this event i thought i was going to lose a finger. but in the end it worked. i don't recommend it though..
Old May 12, 2010 | 03:31 PM
PA-MCS's Avatar
PA-MCS
http://www.promini.com/product-exec/product_id/180
$49 bucks for a oem belt tensioner tool. The cheapest I've found
Old May 12, 2010 | 03:57 PM
moreorless's Avatar
moreorless
So.......
How much are your fingers worth?
Just askin'...........
Old May 13, 2010 | 07:34 AM
cristo's Avatar
cristo
Alliance Member
Originally Posted by moreorless
So.......
One Milllllion Dol -- no, one Billlllion Dollars!
Old May 13, 2010 | 09:51 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Thanks for the link!
Old May 13, 2010 | 10:04 AM
cct1's Avatar
cct1
That's where I got mine. They have a nice pad on the handle, and they also include a nice pin for belt tensioner--really a nice setup for that price...
Old May 13, 2010 | 02:25 PM
cristo's Avatar
cristo
Alliance Member
Cool, they have one for the 1st Gen Justa Cooper for $49 as well.
I know you're supposed to be able to use a 3/8 drive socket wrench for
the Cooper, but it's a tight fit even with a low profile one.
Old May 13, 2010 | 03:14 PM
Capt_bj's Avatar
Capt_bj
Haynes has a diagram for building one
about $10 of flat steel and few bolts after holes are drilled .. or weld it up.
Old May 13, 2010 | 03:47 PM
claancy's Avatar
claancy
Can you post a scan or a photo?
Old May 13, 2010 | 03:52 PM
Capt_bj's Avatar
Capt_bj
you did not say mother may I
but if you PM I just might avoid copyright violations
Old May 13, 2010 | 03:58 PM
JAB 67's Avatar
JAB 67
I built one from a 3 foot length of square stock from Sears; cost me about $6; works fine.
patsum
26
May 29, 2021 06:29 PM
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
Camaro108
Sep 9, 2015 04:37 PM
Camaro108
Sep 9, 2015 01:56 PM
