flat spot , hesitation at 3000 rpm
Old Apr 19, 2010 | 08:40 AM
mplatt911's Avatar
mplatt911
I have noticed a flat spot around 3000 rpm after I installed a 15% pulley and Brisk plugs. Car also has a Milltek exhaust but no other mods. You can drive right through it under full throttle , but when cruising at about 3000 rpm its pretty noticable. I have a "before cat" O2 sensor code but it's been there since putting exhaust on two years ago. Car starts and idles fine. Gas mileage stays around 28-30mpg so I haven't changed the O2 sensor yet.
Thoughts??
TIA
Old Apr 19, 2010 | 08:51 AM
Revolution Mini Works's Avatar
Thoughts??
TIA
the car has the 02-04 software version
it is prone to this especially after upping the boost
changing the timing and a/f ratios will fix that issue
Old Apr 20, 2010 | 06:50 PM
mplatt911's Avatar
mplatt911
sounds good. whats the best way to get that done?
Old Apr 27, 2010 | 04:45 PM
hoonpv's Avatar
hoonpv
uh... call Jan and get the car tuned?
drew-
Old Apr 30, 2010 | 12:16 PM
SeanKidd's Avatar
SeanKidd
check your SC bypass valve...reach under it and activate the lever, it should be slightly tight and instantly return to normal, if it doesn't you have a broken spring...https://www.northamericanmotoring.co...ysis-pics.html
Old Jun 21, 2010 | 08:55 AM
LeeL's Avatar
LeeL
I have an early 2004 MY with a terrible flat spot in the same place now also. Under Part throttle, it feels like I have taken my foot off the gas, just past 3000-3200 RPM, then it comes back around 3700 give or take. Full throttle seesm like so issue. I have had a 15% pulley for years and it has only gotten really bad the last year or so. I have replaced the coil pack, plug wires and plugs and it seems like it might have changed it a bit in the exact revs it comes on at, but it is not really improved.
Is it as simple as a tune?
Old Jun 21, 2010 | 10:23 AM
Yes
Old Jun 21, 2010 | 11:37 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Yes, go with Jan. He'll get you fixed up.
Pker
Apr 11, 2017 12:14 AM
debitsandcredits
Sep 21, 2015 08:34 AM
mtwaddle
Sep 13, 2015 08:10 PM
kjd186
Sep 9, 2015 10:02 AM
Sep 2, 2015 11:15 AM
