Airbag light and Uneven Idle
Old Sep 17, 2009 | 08:26 AM
R53's Avatar
R53
My airbag light has come on (the red light on the speedometer) and i have taken it in to sort it out, well it came back with it off, but after a few days, its back on again. What could the problem be? Could it possibly be the aftermarket software/tune causing this?
Old Sep 17, 2009 | 08:54 AM
thatatvguy's Avatar
thatatvguy
For the idle, plugs or an O2 would be a good place to start.
How many miles?
Old Sep 17, 2009 | 08:59 AM
R53's Avatar
R53
im on 51 000 miles at the moment.
the Plugs/O2 sensor causing the strange idle at random times?
Old Sep 19, 2009 | 11:48 PM
MINItheONE's Avatar
MINItheONE
The airbag light was on mine too. I was afraid it would be an expensive repair but it turned out to be an easy fix just replacing the cables sending the signal from the seat to the dash. What did you dealer do to fix it?
Old Sep 28, 2009 | 09:33 PM
Funsize's Avatar
Funsize
I had the airbag light on in my car so i pulled a tsb on it (lucky me). well there was a silent recall on a connector in the airbag system. it had "micro-cracks" on one of the connectors. mine usually goes away with a key cycle
Old Mar 30, 2010 | 06:14 AM
flyboy2160's Avatar
flyboy2160
do you have the recall number?
thanks.
Old Mar 30, 2010 | 06:24 AM
Helix13mini's Avatar
Helix13mini
The tuning file and plugs are not related to your airbag problem. You're going to have to find someone with a BMW/MINI scan tool to determine which airbag or connector is causing a fault. Rough idle can be caused by many things. If the cause is serious, then you'll get a check engine light as well. Is yours on? Don't start throwing parts at it until you have a better idea of the cause.
Old Mar 30, 2010 | 09:02 AM
JumpingJackFlash's Avatar
JumpingJackFlash
I had an airbag light issue in my old '02 MCS. Thankfully, I had it repaired before my warranty was out. Not sure what they will do if you are past it. Required it to be at the dealership for a week. I was told they had to replace all the related wiring that is under the carpet along the center section front-to-back.
Old Mar 30, 2010 | 04:14 PM
drink8648's Avatar
drink8648
When we bought our used 05 MCS, the overhead and dash airbag light was on. I brought it to a Mini dealer and they said the embedded sensor in the passenger side seat cushion was defective and was a recall issue. I was over the warranty period but they replaced it anyway, no charge.
Teh
Jun 13, 2018 02:59 PM
one73ronin
Aug 19, 2015 12:36 PM
Lt. Dan
Aug 10, 2015 08:23 AM
quality_sound
Aug 7, 2015 09:36 AM
