04 S Battery or Alternator
Old May 14, 2009 | 11:47 AM
lou's Avatar
lou
Driving an 04 with the original battery. Stopped to ask directions last night ( yes I know ) and went to restart the car. Took the second try and upon driving the Power steering 5A fuse had popped. Lights were on for all of this. Went about an hour before next starting and upon starting the following were inactive- low beams, tach, gas gauge,temp gauge and AC/Heat/blower.
Made it home holding the Hi beam lever back to activate the passing lights.
At home tested all of the smaller ( 20A and less fuses ) were ok and reset the 5A PS fuse. Charged the battery for 30 minutes....all was good for a short 1 mile test drive.
Is this a dead battery condition that would be common...please advise as the wife is not a happy camper to be driving this car today!
Old May 15, 2009 | 05:58 AM
lou's Avatar
lou
FOUND IT !
Looks like a simple fix. When I pulled the 5A fuse to get the Power steering back, I borrowed the fuse from one 5A location that indicated a DSC location for fuse...wither one up or down from the PS slot. It was dark, no flashlight, and didn't realize the spares were on the side of the compartment.
Took the battery for testing to the Autozone folks...great shape and is nearly 5 years old.
Went back home...plugged everything in and was OK. Then started pulling fuses to duplicate the failure and found the 5A at fault.
NOW...is a blown Power steering fuse reason for alarm????????
Old May 15, 2009 | 10:07 AM
healey67's Avatar
healey67
Do you have a convertible?
Old May 15, 2009 | 10:49 AM
lou's Avatar
lou
No it is a hardtop--in 2004 no convertibles were available yet.
Old May 15, 2009 | 12:08 PM
robc's Avatar
robc
How does the power steering fan underneath the car look?
-Rob
Old May 15, 2009 | 02:50 PM
lou's Avatar
lou
Battery/ Alt. NO - Power Steering Pump/Fan?
Just got the call from the wife. PS pump out again...same conditions..wet and rainy. I will hop under the car and check the fan operation and if there are any obstructions or wires to be found. Oh boy. Thanks guys.
Old May 15, 2009 | 03:13 PM
robc's Avatar
robc
I think that if the fan is failing or obstructed it can pop the PS pump fuse and/or cause the PS pump to overheat and shutdown. It can get awfully dirty down there and its very exposed if you haven't put a skid plate over it. You'll find it directly behind the oil pan drain bolt.
-Rob
Old May 15, 2009 | 04:14 PM
Oxybluecoop's Avatar
Oxybluecoop
-Rob
Good point and it's worth checking!
Old May 16, 2009 | 06:05 AM
lou's Avatar
lou
Power Steering
Wow...I can't thank you guys enough for the ideas. This time for the failure there were no fuses blown. I jacked up the car and pulled the plastic cover from the cooling fan off. I spun the blades of the fan with my fingers and there was an abrasive sound, dragging feel for a few revolutions and then it freed itself up. Still doing this all by hand. Maybe a small rock was up in there? I don't know yet. Did a few miles test spin and all was good again.
New questions: 1) does the PS shut down when overheating without blowing fuses? 2) would I damage the PS if I drive it again to the point of failure or hard steering ? 3) is there a quick test to see if the fan is still good? 4) is there a vendor on NAM who stocks the PS Cooling fan? it looks easy enough to replace.
Thanks again. I will look up other cases on 2004 S models on the site.
vulkandino
Oct 31, 2015 08:29 PM
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
jennster
Sep 28, 2015 06:19 PM
daviday
Sep 25, 2015 01:31 AM
