Grinding then overheated
I was out today and all of a sudden, I heard loud grinding coming from the engine(Also seemed to have loss of power). Pulled over, popped the hood, noticed the noise seemed to come from the supercharger. I was about 2 miles from home so had to drive it home and it overheated. Anyone ever had this issue? I assume its a supercharger issue, but who knows.
Thanks everyone
Thanks everyone
The lubricant in the water-pump end of your supercharger got low or disappeared altogether. As a result the gears self-destructed and no longer spun the water pump. Thats why your car overheated. Bummer.
Thanks everyone
Thanks everyone
What year? How many miles? Are you original owner? Is this the original supercharger? Had you heard any squeals or grinding sounds in the days and weeks before this event? Stock pulley or undersize? Other mods?
2003, 50000 , second owner, I think the SC is original, I have been noticing some strange grinding sounds this last week, 19% pulley, alta intake.
Given the way that supercharger failures tend to occur (completely random once you get past a certain point), it is tough to blame the failure on the pulley. This certainly wouldnt be the first time a supercharger has failed at this kind of mileage.
So, you have several options now assuming it is indeed the water pump drive (which is what it almost certainly is):
1. Send the one you have now out for a rebuild
2. Buy a new or used supercharger and stick that on there.
3. If the rest of the SC is in good shape you could switch over to an electric water pump.
You used to be able to find used SC's for less than $500, so I might check there first. I would also check and make sure that the overheating has done any damage to the engine (warped head).
unxpectederror
Oct 22, 2015 12:16 PM
FatherG
Oct 3, 2015 05:06 PM
