Drivers door window dipper
Old 01-15-2013, 01:29 AM
actasci's Avatar
actasci
actasci is offline
problem with my mcs 09 is it's utter ********. i thought everything is going perfect first time since 09, no squeals whatsoever, no engine rattling etc... and my windows was dipping, but somehow it's not dipping now. more frustrating thing is -probably many of you guys not having this- if you're in the car, windows closed, when you push the window with your hand (no need much pressure) it moves outwards and wind comes in. it's fking annoying.
my first guess was it may be about freezing temperatures. but i washed it with hot water and that wasn't a fix. i am sick of this car. absolutely sick.
  #252
Old 01-15-2013, 02:52 AM
Copywrites's Avatar
Copywrites
Copywrites is offline
See post 245
The software/firmware updates are the fix, but they do not solve the root problem. The root problem is the window gets frozen in place in cold weather. When you open the door, the window is unable to dip properly, causing it to be out of whack with the software/firmware instructions. From that point forward, it will not work correctly until it is reset again.
If you want to prevent the problem, you have to ensure your windows are not frozen in place when you open the door. I suggest a couple of medium smacks against the glass with the palm of your hand before opening the door. That is what I have been doing for two years now and the problem has not returned. Prior to that, I had the firmware updated and re-installed 4 times.
  #253
Old 01-15-2013, 03:35 AM
actasci's Avatar
actasci
actasci is offline
so i have to take my car to the dealer, no other way?
where i live, it's -15 when i had to go to school. so i don't think there is any visible way to prevent this issue.
-i saw smacking later it is odd and actually quite logical.
  #254
Old 01-17-2013, 08:54 AM
jjshoe's Avatar
jjshoe
jjshoe is offline
I had this problem but it was the result of a module in the car thinking the door wasn't closed. Just one of many issues that resulted in me requesting and getting a dealer buy back.
  #255
Old 04-12-2013, 07:02 PM
Paul Doran's Avatar
Paul Doran
Paul Doran is offline
Was having a driver side dipper problem as well as no Auto up. Turned car on, made sure the window was at the top first, dropped it to the bottom for 5 secs or so and then immediately to the top with NO pause in-between to the top for 5 secs. Fixed the dipper issue and the auto up issues. Right as rain (thank goodness because it was raining when i did it). Will monitor and let you know how it goes, but no trip to the dealer as of yet.
It has been raining a fair bit and a littler cooler 5*C before this problem seemed to happen, just for reference
  #256
Old 01-30-2014, 05:05 PM
JDPaddle's Avatar
JDPaddle
JDPaddle is offline
Wow. Thanks a mil to the forum. 1 hour from dealer �� the simple reset did it for me. Problem was dipped but no up after door was closed. 2013 clubman s. Bought new. 1 yr old. Yeah 20 degrees and below here for the last few weeks. All is right with the world now.
  #257
Old 01-30-2014, 09:39 PM
Copywrites's Avatar
Copywrites
Ok, it has been a year since my last report and I am happy to say the window dip issue has not resurfaced. I religiously ensure the windows are not frozen in place before I open the door. This winter here in Boston, that is a check I have to make every morning. Overall, outside the window dip issue that seemed to drag on for quite some time, my 08' Justa has been remarkably trouble free for ~60k miles. No complaints.
  #258
Old 11-29-2016, 02:39 AM
Lynxblaine's Avatar
Lynxblaine
Lynxblaine is offline
Hi
Has anyone who had this done out of warranty had to pay for the software to be initialized?
  #259
Old 11-29-2016, 10:57 AM
MiniShield's Avatar
MiniShield
MiniShield is offline
No Charge
I bought mine in way after warranty and did not get charged. Maybe because I had it in for an oil change and some other stuff.
  #260
Old 01-05-2017, 10:41 AM
nomar116's Avatar
nomar116
nomar116 is offline
My windows were dipping but not auto closing. Resetting fixed the glitch! Thanks so much!
  #261
Old 01-15-2018, 03:15 PM
Convincor's Avatar
Convincor
Convincor is offline
What do you do before you open if they are frozen in place?
  #262
Old 01-16-2018, 08:44 AM
automan21's Avatar
automan21
automan21 is offline
What ive noticed
It’s not really the seal around the top and side of the window that’s freezing. In my case it’s the bottom seal with the chrome trim. Water and ice stay there and then the window sticks. What I do is take a plastic card, credit card or whatever of that nature and put it on between the seal and window then run it right across. Frees up the window and you can then open it up and it will dip.
Convincor (01-16-2018)
  #263
Old 08-30-2019, 01:43 PM
Rob Rocheleau's Avatar
Rob Rocheleau
Rob Rocheleau is offline
Hello,
Just to answer this old question. Out of warranty, I had to pay for 1 hour of diagnostic time @ $147 an hour. The total time at the dealership was 2.5 hours.
I brought in the Technical Service Bulletin (TSB SI M51 02 08) to request just the re-program on the window for the anti-pinch function. Prior to me providing the TSB, the advisor was suggesting the the window track might need to be replaced along with the motor. Stating that was the likely reason that the window was stuck down. Even though the window was fully closed by bumping the switch to tease it to a nearly closed tight position.
Just to add insult to injury, I tried several Mini dealers service online chats, and none of them returned my inquiry requesting to do a window re-program.
I tried the manual reset procedure twice as directed in the TSB and factory reset procedure. Finally, I had to give in. My next task will be to read up about the various software tools and cables available and see if this can be a DIY project for next time?
This is the text of "diagnosis":
CLIENT STATE THAT WINDOW IS STUCK DOWN HE NEEDS IT REPROGRAMMED
found window lost initialization
connected battery charger and interrogated fault memory
found fault codes stored for drivers window syncronization
performed visual inspection of window and operation of window,
found window anti trapping at up-most position.
performed test plan on fault code, re-synchronized drivers and passenger side power windows.
Found windows operating as designed. Tested several times.
Advise client to monitor. If window loses synchronization again there may be an issue that would need further diagnosis.
Hope this adds to the collective knowledge on the subject.
  #264
Old 08-31-2019, 04:51 AM
gregsmini's Avatar
gregsmini
gregsmini is offline
Hi Rob,
I use the "Carly" app which diagnoses and can clear Mini codes. You need to buy an OBD2 adapter that plugs into your car, so the whole setup isn't cheap. Here is a link to their site https://www.mycarly.com/en/app/bmw/ .
It gives you an idea of what's going on with the car and may avoid costly dealer visits.
Greg
  #265
Old 08-31-2019, 04:54 AM
Rob Rocheleau
Originally Posted by gregsmini
Hi Rob,
Greg
Thanks for the information. My end goal is to learn as much as I can about the car, so I can mini-mize the trips to the dealer (Pun intended)
Rob
melmahon
12-16-2009 09:06 AM
bunce
09-17-2008 08:52 PM
jefflaw
09-01-2007 08:55 PM
Otterpup
03-25-2003 01:11 PM
zeabre
01-22-2003 10:36 AM
Quick Reply: Drivers door window dipper
