R50/53 Issues with door window not inching up and down when opened and closed
Old Aug 11, 2008 | 05:24 PM
bunce's Avatar
bunce
As the title suggests, when I open the door the glass doesn't slide down. and then when i close it, it catches on the trip above.
I've a bad feeling about this, please help ???
Old Aug 11, 2008 | 06:00 PM
chaseabryant's Avatar
chaseabryant
It is probably a problem with either your window motor or your window regulator. Also, have you checked your fuses?
Are you able to put your window down? If your window is able to be put down, try holding your window switch up for five seconds, this resets the window memory that tells the car where all the way up is located...
Any way, I'll be glad to try and help you out some more with a little more information!
-Chase
Old Aug 11, 2008 | 08:24 PM
bunce's Avatar
bunce
That seems to have done the trick, Thanks
Old Aug 11, 2008 | 08:45 PM
chaseabryant
Good to hear!
-Chase
Old Sep 16, 2008 | 08:30 AM
AutoXR53's Avatar
AutoXR53
-Chase
So if the window doesn't move at all I should try this before condemning the regulator? I can hear the motor clicking the window just won't move.
Old Sep 16, 2008 | 09:07 AM
chaseabryant
if the window just clicks, it sounds like the regulator. One thing you can try doing is taking your door card off, and pounding (I know that it sounds sort of terrible...) on the small area below the small speaker and your door handle; that is right where the motor and the cable pulley are located. (There should be three gold screw heads in the area that you should be pounding on.
Unfortunately, just this week, when it has been getting really hot and my car has been sitting in the sun, my window hasn't been very happy a couple of times, and just did the clicking gig. Luckily, with a good pound it was fixed and hasn't bound up again....
If the pounding doesn't work, then I think that you may have to replace the regulator.
-Chase
Old Sep 16, 2008 | 09:14 AM
AutoXR53's Avatar
AutoXR53
I've been thinking it's the regulator but I was just thinking "well maybe it's something else". I was mainly trying to fool myself so I didn't take the door apart tomorrow morning and whip out the ol DMM lol
I would try hitting it, but the thing is it's stuck up, I don't want it to get stuck down haha
Old Sep 17, 2008 | 09:53 AM
AutoXR53's Avatar
AutoXR53
it's the freakin regulator!! plenty of power to the motor just nothing... freakin thing. Guess Ill have to order one eventually.
Old Sep 17, 2008 | 12:25 PM
chaseabryant
they're not too expensive, especially for the size of part, plus, they are normally in stock at your local dealer!
-Chase
Old Sep 17, 2008 | 01:21 PM
AutoXR53's Avatar
AutoXR53
yeah... local dealer is 2 hours away lol. I actually found one on
www.alleuropeanautoparts.com for about $145 shipped
Old Sep 17, 2008 | 08:52 PM
markldriskill's Avatar
markldriskill
A least the regulator is better than the motor crapping out!
Chase -- Those are some cool tips. Thanks!
Dec 23, 2015 10:36 AM
skippermini
Aug 13, 2015 06:13 AM
Dashdog
Aug 10, 2015 06:17 AM
SoCalledFriend
Aug 6, 2015 06:59 AM
