Finally, a new transmission after 14 months of complaining
Old Aug 12, 2008 | 09:53 AM
rstalter77's Avatar
rstalter77
So, after 14 months of telling them it needs replaced I finally broke my dealership and they replaced the transmission. The only problem is the part# on the new trans does not match the part # on realoem.com. I have a 2007 R56 Cooper S w/ LSD
New replacement transmission part# 23-00-7-568-719
Old broken transmission part# 23-00-7-573-131
Can anyone confirm that this new trans. has a LSD? I think they replaced it w/ the wrong one.
Old Aug 12, 2008 | 05:15 PM
NZ_M3's Avatar
NZ_M3
Just take a look in the hole where the driveshafts go into the transmission - if you see a diff pin then it's non LSD, if it's just a hole with nothing in between then it's LSD>
Old Aug 13, 2008 | 09:55 AM
Ian Venieri's Avatar
Ian Venieri
One tire on terra ferma and the other on loose or wet ground will provide the answer.
Old Aug 13, 2008 | 12:15 PM
ianparcher's Avatar
ianparcher
Do a burn out!!! one tire mark no lsd, two marks you have one...simple
Old Aug 18, 2008 | 06:34 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
are you able to take a picture as an example of what you are talking about?
Old Aug 18, 2008 | 06:42 PM
NZ_M3's Avatar
NZ_M3
Not from a mini gearbox, but applies for all FWD LSDs
Image from Honda gearbox
LSD: you can see right through the hole
No LSD (see the diff pin)
or this one sums it up
Old Aug 18, 2008 | 08:07 PM
Xray'dit_Mini
thanks for the pics
I was hoping there was a way without having to remove the axel shafts =)
Old Aug 20, 2008 | 11:13 AM
baggerben's Avatar
baggerben
go out and light up the tires. do a quick burn out.
Old Sep 2, 2008 | 06:38 AM
unclemeat's Avatar
unclemeat
turn off DSC. Take a turn after the light goes green and hammer the gas in 2nd gear. If inside tires smokes: no lsd.
Old Sep 7, 2008 | 05:22 PM
MotorMouth's Avatar
MotorMouth
not true.
I have lsd and can still smoke the inside tire, just not as much as if I didn't.
better test. If you leave two black streaks you've got it. If you don't then the test is inconclusive. Even with LSD one tires gets more power than the other. It is not a 50/50 split.
best test. make sure one tire is on a very slippery surface so it has little to no traction. if you can still drive forward - bingo. haveing the e-brake on can help to make sure.
Old Sep 26, 2008 | 11:09 AM
andstillgoin's Avatar
andstillgoin
Mine's scheduled for a new tranny tomorrow so I called the SA to verify the replacement has LSD. He did some checking ...replacement parts are based on the car's VIN ...my car's VIN shows it's equipped with LSD ...they ordered a replacement tranny with LSD.
just to add... part #23007573131 on realoem.com shows up as the part number for a 6spd MT w/ LSD.
Old Oct 29, 2008 | 07:40 AM
ColinMc's Avatar
ColinMc
Can I ask why you guys had new trannies put in? I'm having issues with my 6sp manual where shifting to 5th and 6th at speed is SUPER stiff...as in my mom can barely do it when she borrowed my car. The "Shop Foreman" says it's normal and some Mini's are even more stiff...
It wasn't always like this...and it's a little disappointing when my 95 Taurus SHO had a nicer shift mechanism.
Old Oct 29, 2008 | 08:23 AM
andstillgoin
ColinMC - that doesn't sound normal.
With ~3K miles, mine started out with some driveline chattering when taking off in 1st & 2nd gear which quickly manifested itself to a slipping clutch when on boost in 2nd. Following morning I had a puddle of gear oil on my garage floor. Problem ended up being a loose input shaft resulting in a new tranny; they don't repair the trannies at the dealership, they only swap them out.
Almost at 6K miles, shifts are still smooth.
Old Oct 29, 2008 | 08:53 AM
ColinMc's Avatar
ColinMc
Yeah it has me worried...mine isn't the severe problems you say...but it's still annoying when mine suddenly got stiff a while ago and the "shop foreman" says that's normal...I used to be able to use 2 fingers to shift now I gotta full fist it or that shifter isn't going anywhere. I want to install a short shifter I have sitting in my room in the box, but won't do it yet figuring they'll blame that for the problem...or it might be even harder to shift i'm guessing with that installed.
EDIT: I started posting in my original thread about this so I don't get this one way off topic...sorry
Teh
Jun 13, 2018 02:59 PM
Markbett
Jul 3, 2016 04:28 PM
maytulip32
Aug 27, 2015 04:59 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
ludedude
Aug 10, 2015 07:16 PM
