Factory toe-in setting for an MCS?
Old Aug 15, 2003 | 11:03 AM
dominicminicoopers's Avatar
dominicminicoopers
What is the factory toe-in setting for MCS's?
Old Aug 15, 2003 | 11:15 AM
8ball's Avatar
8ball
... all i've found so far is Optical:
Camber = -30' +/-25'
... why do you ask?
... maybe the TireRack guys could get a number too (tire & wheel forum?)
Old Aug 15, 2003 | 11:18 AM
dominicminicoopers
What I'm after is the front wheel toe-in/toe-out setting. I know some racers are going with a slight (under 1 deg) of toe-out.
Old Aug 15, 2003 | 11:31 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
check the settings in the second to the last post in this thread for the toe in settings-
https://www.northamericanmotoring.co...amp;topic=9726
Old Aug 15, 2003 | 01:47 PM
dominicminicoopers
Thanks for the link. I printed that information.
If I were to get a professional alignment, what type of shop does that? Is there a particular alignment machine that's better than another?
Old Aug 15, 2003 | 08:01 PM
dpayne1's Avatar
dpayne1
I've had about 6 alignments this year at a local shop. On the sheet they give me with the before and after results they also list the specified range
For front toe it's -0.03 to 0.03, with total front toe from -0.05 to 0.05. On the front, I usually run 0 or neutral, with a slight toe out in the back - that's primarily an autocross setup.
I'm considering your wheels that are for sale
David
Old Aug 15, 2003 | 08:16 PM
minihune's Avatar
minihune
I had my alignment done at a brake and alignment specialty shop- that's all they do. They had about 5 or 6 bays and specifically used a certain bay for my MINI.
I don't know the name of the equiptment that was used but I'm sure that this type of shop would know what to do even if a MINI had suspension upgrades which I did have. They can do adjustment however you want from factory settings to autocross or custom.
Old Aug 15, 2003 | 09:39 PM
dominicminicoopers
There's a Fletcher's Auto not too far from me. I checked with them on the way by just at their closing time. They do alignments for 69.00. I'm taking it there early next week.
Thanks again for all the information!
Happy Motoring
Dominic
p.s. The Kosei wheels would be awesome for someone who races. Light and wide. I just added my latest pix of th wheels (tires have been removed from them now).
Old Aug 19, 2003 | 09:20 PM
dominicminicoopers
Well, I took it to Fletcher's and the toe front and toe rear were out of spec. They also leveled the steering wheel. Good stuff! Only $69.00! :smile:
eatsleepautox
Oct 30, 2015 06:46 AM
theblackfalcon
Oct 11, 2015 09:49 AM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
