Does anyone hear this noise?
Old Oct 16, 2007 | 09:45 PM
sirr6's Avatar
sirr6
I hear it sometimes after the car is turned off, I hear these popping noise from the rear driver tire area, I didnt listen to the passenger yet, but its a "thump!" noise about every 10-20 secs, is that normal? And sometimes when I go over speed bumps, I hear a "thump" also, is that normal too?
Old Oct 16, 2007 | 10:01 PM
pastabatman's Avatar
pastabatman
I think I noticed the same thing a couple of times now (just got the car last week). Seemed like the sound was coming from the rear of the car, near the exhaust. Little 'pop' sounds, ever 10-20 seconds, for a short while. Quite a 'thump', as you said. I got the distinct impression of moisture dripping onto a boiling hot surface. Both times I got out and went to the back to see what was going on. Saw and heard nothing.
Old Oct 16, 2007 | 11:24 PM
sirr6's Avatar
sirr6
That can be true were the moisture, but i hear it when theres no rain or if the car has not been washed.
Old Oct 16, 2007 | 11:33 PM
pastabatman
Same here. Condensation from AC?
Old Oct 16, 2007 | 11:51 PM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
I get a thump or clunk sound now and then after I set my parking brake when my rotors have not cooled down enough that comes from the rear of the car. Where I live its very flat and do not set the hand brake much.
Old Oct 17, 2007 | 04:46 AM
korby's Avatar
korby
My guess it's something to to with the turbo cooling and releasing the heat out the tail . One cold morning mine was making smoke rings each time it popped .
Old Oct 17, 2007 | 05:51 AM
tomah's Avatar
tomah
my made the popping sound the other day. sounds litterally like. POP
Old Oct 17, 2007 | 05:54 AM
jrammon's Avatar
jrammon
I get the "thumping" sound too. Next time you hear it remove and reinstall your gas cap. I believe it is built up pressure that is "thumping" the vent in the gas tank. I also believe the vent is working because when I do remove the gas cap it does not release a gush of vapor. But after I remove and replace the gas cap the "thumping" goes away.
Old Oct 17, 2007 | 07:01 AM
lacning74's Avatar
lacning74
When idling, I also have the same sound from the rear in my mini cooper non-s. It is a low thumping sound, around 10 second interval.
Old Oct 17, 2007 | 07:12 AM
r56mini's Avatar
r56mini
Yes, there are other threads on this and the noise is caused by gas pressure being released in the fuel tank.
Old Oct 17, 2007 | 07:29 AM
Beebe's Avatar
Beebe
I think my MCSa has this noise! To me, it sounds like a groaning thump from near the rear passenger side. It sounded like a brake or wheel noise to me. I didn't notice until after I had filled the tank with gas for the first time. Mine will go on for quite a while, usually 5-10 min but, I've even heard it do it an hour or so after the car is parked. I was going to call the service dept and ask them about it. I will try the gas cap trick. My car is less than a month old.
Old Oct 17, 2007 | 10:18 AM
djam43's Avatar
djam43
Mini Farts!
Old Oct 17, 2007 | 11:40 AM
sirr6's Avatar
sirr6
i will try that, so, we all agree that this noise is normal and our mini's wont blow up while were driving?
Old Oct 17, 2007 | 01:10 PM
PaulCIssa's Avatar
PaulCIssa
Originally Posted by djam43
Mini Farts!
YIKES! Who cut the cheese?
Old Oct 18, 2007 | 07:43 PM
Beebe's Avatar
Beebe
Is this noise worse when the gas tank is full or close to full? I'm down to 4 wedges and the noise is now gone. Anyone notice this?
Old Oct 19, 2007 | 06:56 AM
lacning74's Avatar
lacning74
Now that you mentioned it, I think you are right. I do notice the noise especially after recent fill-ups. I'll pay attention now.
lweaver
Sep 17, 2024 08:22 AM
Supertractor3
Apr 7, 2017 11:16 AM
rob&JCW
Oct 9, 2015 11:12 AM
Septimusminious
Sep 14, 2015 08:47 PM
rob&JCW
Sep 10, 2015 12:06 PM
