Garage Door Opener
Old Aug 14, 2007 | 05:00 AM
ucbrother's Avatar
ucbrother
Garage Door Opener
Has anyone had any success programming the convienence package garage door control? I followed the instructions in the manual, and everything seemed to work according to the book, all except for the actually controlling of my door. Is there some limit on how old your opener can be in order for this feature to work? I have a Sears Craftsman, less than 10 years old. Anybody else experience this?
Old Aug 14, 2007 | 06:02 AM
Robin Casady's Avatar
Robin Casady
Mine opens the door half the time. Probably something about a dual signal security measure. Supposedly, there is a way to set it for this, but it takes two people. I find it easier to carry the door remote. The location of the buttons on the mirror is inconvenient, to me.
Old Aug 14, 2007 | 06:03 AM
Minidrivr's Avatar
Minidrivr
Does your garage door roll codes for the remotes? Did you hit the button on the door opener to tell it you are programming a new remote?
Old Aug 14, 2007 | 06:04 AM
Loony2N's Avatar
Loony2N
Older "roving" security openers are more of a problem than newer ones. That's probably your issue. I don't have a garage. But, I was thinking of building one so I don't have unused buttons on my MINI.
Old Aug 14, 2007 | 06:44 AM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
Mine works fine, as long as I hold the button for a moment. A quick press on it doesn't seem to work but if I press and hold for a couple of seconds it opens and closes the door without any problems.
Old Aug 14, 2007 | 03:46 PM
JeffreyC's Avatar
JeffreyC
Mine works fine as well. 3 yr old Lift Master opener.
Old Aug 14, 2007 | 04:20 PM
emtrey's Avatar
emtrey
Mine works fine. My GDO is old and does not have rolling codes.
Old Aug 14, 2007 | 04:26 PM
bahawton's Avatar
bahawton
I have it on my 2006 JCW MCS- Haven't been able to make it work yet either : (
Old Aug 14, 2007 | 06:55 PM
jimsevo8's Avatar
jimsevo8
If your garage door opener is the "rolling code" type you first need to program it to the opener in the vehicle. The owner's manual tells you how to do this. Once that is done, then there should be a button on the opener itself (usually up by the light) You press that to put it into "learning mode", then press the button on the opener in the mirror. You might have to do it a couple of times for the opener to learn the code. Hope this helps.
Old Aug 14, 2007 | 11:03 PM
Sin MINI's Avatar
Sin MINI
Old Aug 15, 2007 | 01:28 AM
Robin Casady
My garage door opener is probably 19 years old. IIRC, the manual says you need two people to program it for "roving" doors. I live alone and haven't "volunteered" anyone to help me do it. Velcroing the remote to the passenger side of the shift console seems more convenient. It is an easier reach than the mirror.
Old Aug 18, 2007 | 05:22 AM
MrVvrroomm's Avatar
MrVvrroomm
Mine works fine on 3 of my 4 garage doors. Why can't I get it to work on the 4th? LOL
Follow the directions, exactly, and it will work. It's not a MINI thing, it's a HomeLink thing. I have a HomeLink mirror in my Subaru that also works fine.
Old Aug 24, 2007 | 03:22 PM
ucbrother's Avatar
ucbrother
Finally got some time to figure out what was going on. My opener is in fact a "rolling code" type. Once I determined that, I researched my model on the web to find an owner's manual. I found one close enough, and to make a long story short, everything works fine now. I inadvertently wiped out the codes for my two original remotes in the process, along with the outside keypad, but I reprogrammed them and all is well.
Thanks!
Old Aug 24, 2007 | 04:30 PM
Minidrivr's Avatar
Minidrivr
Thanks!
That's good to hear you have it working now. My door opener is a roller code one also so you had me worried...
spackletooms
Sep 1, 2015 10:12 PM
caiken
Aug 30, 2015 05:34 PM
Bennyboy
Aug 18, 2015 07:28 AM
SoCalledFriend
Aug 6, 2015 06:59 AM
