MCS feels like it is "missing" at about 70MPH
Old Aug 11, 2007 | 10:19 PM
MudderDucS2R's Avatar
MudderDucS2R
I have 6500 miles on my '06 MCS, & on a trip this weekend, it felt like it was "missing" around 70. My husband said he's noticed it awhile ago, but the MINI dealership said if it was, I'd get an engine light. ANyone else having this problem? I'd love to go into the dealership & tell them what to do to fix this. Could it be the mapping?
Old Aug 11, 2007 | 11:51 PM
Alerious's Avatar
Alerious
Perhaps it's just me, but could you clarify "missing"?
GotMINI
Old Aug 12, 2007 | 05:26 AM
PaulCIssa's Avatar
PaulCIssa
"Missing" = Misfiring.
Old Aug 12, 2007 | 06:42 AM
MINIFVR's Avatar
MINIFVR
That sounds strange. Maybe its the high RPMs of a small 4 banger thats making it feel like its missing. 4 cylinder engines are not smooth in any way and I find that at highway speeds it does feel a bit odd.
Old Aug 12, 2007 | 09:49 AM
pengrayghost's Avatar
pengrayghost
missing
70 mph in 6th gear is approx 3000rpm in my 06 and it may be the dreaded "yo-yo" effect. I can sometimes feel what seems more like a small surge than an actual miss. No good solution for you except perhaps a reflash to ecu to correct it. I haven't done this as its two and a half hours to the nearest dealer. Good luk, Jim
Old Aug 12, 2007 | 12:01 PM
SB's Avatar
SB
It feels like a miss from an old car, right? A small jerking sensation coming from the motor at only that rpm level while cruising the interstate. Correct? An update from the dealer isn't going to fix it. Or atleast not mine. A DT bpv did not help either.
Old Aug 12, 2007 | 12:23 PM
Bradley99's Avatar
Bradley99
Originally Posted by pengrayghost
<snip> it may be the dreaded "yo-yo" effect. I can sometimes feel what seems more like a small surge than an actual miss. No good solution for you except perhaps a reflash to ecu to correct it. <snip>
You might try VGS to cure the yo-yo. Very low $$, easily reversible.
Old Aug 12, 2007 | 02:06 PM
herbie hind's Avatar
herbie hind
+1
Old Aug 12, 2007 | 05:30 PM
PaulCIssa's Avatar
PaulCIssa
So what is the dreaded "yo-yo" condition? Is it a closed-loop, lean condition? The reason I ask is because I fought that battle on my 2002 BMW R1150RT motorcycle. Same issue: at speed, cruising at partial throttle openings. It required an additional aftermarket device to set a new fuel map. A couple hundred dollars later, the bike ran like a different machine.
Old Aug 13, 2007 | 05:19 PM
herbie hind
my giac flash got rid of any hint of it . but honestly i had very little to begin with. the detroit tuned bpv actually gave me the yo yo . so i did what the doc did and adjusted the stocker for a better seal . it has to do with where the engine starts to close the bpv. i wonder if this is why they changed the gearing on the 06's ?
Old Aug 13, 2007 | 05:25 PM
lhoboy's Avatar
lhoboy
My MCS runs smooth as silk at any rpm. If yours isn't, you may want to have someone look at it.
Old Aug 15, 2009 | 09:52 AM
DMBFan2's Avatar
DMBFan2
Did you get the "missing" effect dealt with? I have been noticing the same thing @3000rpm/70mph during small inclines while on the freeway. It has become more noticeable over a gradual period of time as well. I thought that it had something to do with the supercharger but I have a new one (now with 40k miles on it) that was installed by the dealer in Scottsdale. They are really good at what they do, so I figure that it might be something else.
At first I thought it had something to do with the high temperatures since I live in AZ. but because others have had this same issue in other regions, I doubt the heat has a substantial amount to do with it.
I am lost with this...the only thing I have done to my 03S is adding Royal Purple engine oil, Redline trans. fluid, Cobalt wires, NGK1 plugs and a K&N air filter. Nothing dramatic.
Also, I have noticed that shifting has changed as well. What I mean is, lets say that the vehicle usually shifts from 2nd. to 3rd. at 25mph. Now it shifts around 45mph. I know someone will say its operator error, but that is not what I am getting at. What I mean is that there does noes seem to be enough power to shift at the usual 25mph. Hope that makes sense.
Any ideas?
bansasn
15
Sep 4, 2015 01:24 PM
minibenworks
Aug 30, 2015 08:45 PM
Drumsound
Aug 25, 2015 02:25 PM
massmini03
Aug 12, 2015 11:19 AM
nomar116
Aug 10, 2015 11:24 PM
