Passenger Window Wont Open
Old Aug 10, 2007 | 04:06 PM
DrkSilver163's Avatar
DrkSilver163
Hey everybody,
Quick question...my passenger window will not open at all. I hear a clicking noise whenever i hit the switch, but its just one click. The driver door works fine, and the fuse is ok. A while back i put ian cull's auto up circuit, so i dont know if that had anyhting to do with it. I dont think it would. I am out of warranty, so if anyone can share a similar experience and how they solved it. Thanks
Marco
Old Aug 10, 2007 | 04:09 PM
Eric_Rowland's Avatar
Eric_Rowland
No, Ian's circuit has nothing to do with it.
Your window motor is going out - a not uncommon issue.
For a temporary fix, while holding the switch down, bang on the inside of the door below the door handle.
Then, prepare to get the motor replaced in the future.
Old Aug 10, 2007 | 05:18 PM
joey1320's Avatar
joey1320
try the quick fix he mentioned but you don't have to hold down the switch for it to work. and yeah you will need a new motor really soon.
Old Aug 11, 2007 | 10:01 PM
NJMiniS's Avatar
NJMiniS
Yup - had to replace the driver side window motor at about 60K same problem.....
Old Aug 15, 2007 | 11:40 AM
supercliff's Avatar
supercliff
mine has the same problems 03 MCS. Just took it to the dealer, they are going to replace the motor under warrantee and also replace the track and guides for the driver side. There is a TSB out for this.
Old Aug 15, 2007 | 04:27 PM
DrkSilver163
I gave it the fonzie touch and for now it works. Hopefully itll say working for a while. thanks
Old Aug 15, 2007 | 04:34 PM
AKIndiMini's Avatar
AKIndiMini
Do you happen to know what the TSB covers? I don't want to hijack the thread, but the windows on my MCS just started squealing in warm weather. I was thinking this could be one of the first signs of the motor failing...
Old Aug 15, 2007 | 07:40 PM
joey1320's Avatar
joey1320
the window squeal is not because of a motor issue is because of the regulator. the window regulator needs to be lubricated.
good luck!
Old Aug 16, 2007 | 09:48 AM
Speedwing's Avatar
Speedwing
My driver window on our 2005 R50 was squealing occasionally. Otto's MINI lubed both sides (no charge). Great service!
Old Aug 16, 2007 | 10:32 AM
AKIndiMini's Avatar
AKIndiMini
I'll have to remove the door cards and try lubing the regulator. Thanks for the tip!
Old Aug 16, 2007 | 01:09 PM
Eric_Rowland
Originally Posted by DrkSilver163
I gave it the fonzie touch ...
cub4bearindiana
Jun 30, 2016 06:11 AM
hardy616
Sep 2, 2015 08:32 AM
spackletooms
Sep 1, 2015 10:12 PM
clintmeister
Aug 12, 2015 11:11 AM
