Manual Transmission Oil Leakage
Old Jul 21, 2007 | 07:01 AM
mini07's Avatar
mini07
With only 2,500 miles on it my R56-S developed a manual transmission oil leakage, took it to the dealer and the diagnosis is, a faulty seal on the power shaft. Will like to know if someone else have seen this happen to an '07.
Tks.
Old Jul 21, 2007 | 10:20 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
I had what was originally thought to be a tranny leak on my three week old 07 MCS 6spd, but it turned out to be the rear main seal.
Old Jul 22, 2007 | 04:51 AM
PaulCIssa's Avatar
PaulCIssa
Ouch! That smarts!
Old Nov 16, 2007 | 06:47 PM
Duffer's Avatar
Duffer
I had the oil changed today at 1800 miles and noticed that gear oil appears to be leaking around the axle or drive shaft.
Old Nov 16, 2007 | 07:01 PM
user 7082082's Avatar
user 7082082
Same thing is happening on my r53 right now. Its a very very small leak and the dealer told me that I could get it fixed right before warrantee ends, since it will most probably happend again.
Old Nov 16, 2007 | 07:28 PM
n1tr0's Avatar
n1tr0
power shaft ? you mean the input shaft ?
Old Nov 17, 2007 | 04:43 AM
Duffer's Avatar
Duffer
To be honest I'm not sure, but there was a shaft coming out of the passenger side of the transmission, and the oil appeared to be leaking around that shaft.
FYI I couldn't follow your link.
Old Nov 17, 2007 | 09:11 AM
n1tr0's Avatar
n1tr0
that'd be the passenger side drive/axle shaft. not a huge deal, but none of the seals should be failing when it's brand new, probably got nicked on assembly.
minicoclub
Nov 11, 2015 07:25 AM
FrostyFox
Oct 28, 2015 02:06 PM
theblackfalcon
Oct 11, 2015 09:49 AM
imanexcellentdriver
Aug 31, 2015 08:08 PM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
