Air Bag light stays on
Old May 30, 2007 | 08:44 AM
Silverbullit's Avatar
Silverbullit
When I started my car on Tues. morning the air bag warning light came on
and didn't go off. It's still on today. 2006 MCS. Is there a special trick to getting it to reset or is it a trip to the Dealer as the book says. My Dealer is 120 miles away. Thanks for any help.
06MCS/DS/B/Bbonnetstripes/Whalen8ballshiftmachine
Old May 30, 2007 | 09:38 AM
blackman's Avatar
blackman
i have the same problem, i had my car in twice to the dealer already for the airbag light, the first time was a defective part under the seat somewhere i think, the second time it had jus become unplugged. those were both under warranty, now my light came on again to, and my car is off warranty, so i am leiry bout bringing it in, bmw is $$$!:impatient
Old May 30, 2007 | 12:40 PM
minimusprime's Avatar
minimusprime
same problem... they say it's a sensor under the passenger seat... I could prob fix it myself in under an hour... but they say they want my car for an entire day.
Old May 30, 2007 | 12:43 PM
Yo'sDad's Avatar
Yo'sDad
Once your AB system is tripped, it will not reset itself by itself. Someone with a scan tool that has airbag capability built in is required. I unplugged my airbag wire under the seat when I was doing other things and forgot and turned on the key.... wham... red light. I'm just going to live with the light till I need to go back to the dealer for something.
YD
Old May 30, 2007 | 01:56 PM
snid's Avatar
snid
Most likely, it's the wiring harness for the seat airbags. Replacing the wiring takes a couple of hours at least. It should be covered under warranty. I have yet to find anyone other than the dealership that can reset the light. Lots of people say "anyone with a scan tool can do it", but I haven't seen it actually happen yet. I called all the local independent BMW specialists, and they all said they could not reset the light.
Old May 30, 2007 | 05:18 PM
earlrabbit's Avatar
earlrabbit
I just had the same problem with mine and was anticipating the worst case (lots of $$$). Dealer ended up replacing the electrical connections under both seats - covered under the 150000 mile airbag warranty. No charge!!!
Old May 31, 2007 | 06:42 AM
Silverbullit
Thanks for all your input. I'm going to call the Dealer today and make an appt. I e-mailed for an appt. on Wed. but no reply so I suppose they don't really care if I bring my car for service or not. This is the third time with this Dealer and the other two were less than what i expected. I'm about ready to drive to Indy and have the Dealer i bought the car from fix it. At least they would be happy to see me. I guess when you live in the "Boon Docks" this is the price you pay.
Old May 31, 2007 | 06:47 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Mine is on, I thought it was the harness, so I took it in...I need the entire passenger side airbag replaced! I was quoted at $1200 after parts and labor...don't be too cheery yet, not until your problem is diagnosed atleast.
Old May 31, 2007 | 08:00 AM
kesh420's Avatar
kesh420
Put the driver side seatbelt in the passenger belt buckle and vice versa. Sounds crazy, but it worked for me.
Old May 31, 2007 | 08:34 AM
Motor On's Avatar
Motor On
Get some wire, spice around the connectors between the seat and the cars harness, then get a scan tool w/ BMW airbag ability and clear the light. they had a design flaw in the connectors, unless you got the redesgined ones when you were in last time this is cheaper and from what I've read the procedure for a 3rd visit for that issue. Plus the code reader with BMW airbag would confirm this really is the problem.
only works if its just weight on the the sensor and only the top not both lights.
Old May 31, 2007 | 08:40 AM
obehave's Avatar
obehave
I wouldn't be too positive you got a perfect diagnosis either.
Any way to get a 2nd opinion?
Old May 31, 2007 | 08:41 AM
obehave's Avatar
obehave
Any suggestions and part numbers for said BMW scan tool w/airbag capabilities?
Jeremy1026's Avatar
Jeremy1026
Moderator
I just tried the seat belt thing on my MINI, only my top light is on...now it blinks a few times at start up and then stays on :(
Old May 31, 2007 | 08:45 AM
Motor On's Avatar
Motor On
Peak makes a tool that reads just Airbags on the BMW system, sorry dont have more info on that, might be on the MiniMania website just make sure it is not their ONDII reader. It's my backup plan if the light ever returns. Hoping it wont come to that point though.
Old May 31, 2007 | 09:05 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
http://www.peakeresearch.com/srstool.htm like this one motoron?
Old May 31, 2007 | 09:07 AM
Motor On's Avatar
Motor On
Yup that would be the one I would order if I develop this issue, after calling them to see if they could assure me I wouldn't have any issues using it witha MINI.
Old May 31, 2007 | 05:54 PM
Silverbullit
I'm taking the car into MINI of South Atlanta {was Hank Arron MINI ] on Mon. as I have a couple other issues under warranty also. We shall see!!
Thanks again everyone for your input.
Old Jul 17, 2008 | 03:01 AM
Tom S's Avatar
Tom S
My first post here, still trying to get a Mini here in Anchorage Alaska. Bad news on the reset tool, doesn't work on the airbag light.
My e-mail to Peak:
----- Original Message -----
Tom S
> Searching your site for a tool to reset an airbag light on a 2002 Mini
> Cooper S lead me to this:
> http://www.peakeresearch.com/emx.htm
> The R5/EMX
> Scan/Reset Tool for Mini Cooper 2001-2006
> Now Available!!!
> Reads all engine fault codes, resets service engine soon, oilservice
> and inspection!
> My question is, does this also reset the airbag light? The above
> description does not specifically include this.
> I have not bought the car yet as the owners have had it in an
> independent shop here for a week now. They are trying to get this
> reset after the same shop previously replaced some of the, I assume,
> airbag wiring harness. So far they have failed. There are no Mini
> Cooper dealers here.
> If I ever get my hands on this car I will be ordering this tool. I
> hope you can sent it via the US Mail. : )
> Thanks in advance for your reply.
----- Original Message ----- From: "Adam" <support@peakeresearch.com>
To: "Tom S
Cc: "dan" <tcs@peakeresearch.com>
Sent: Wednesday, July 16, 2008 7:59 AM
Subject: Re: Customer Inquiry - R5 Tools
Dear Mr. S,
Thank you for your interest in Peake Research.
The R5/EMX tool will not reset the airbag light. We do not currently
offer a tool that will reset the airbag light on a Mini.
We ship our tools through USPS or UPS depending on the customer's choice.
Best regards,
Adam
Peake Research
www.r5tool.com
Old Sep 6, 2008 | 08:48 PM
BEAVR's Avatar
BEAVR
Tom S, I'm sure you've solved it by now, but the autoenginuity enhanced with BMW software and hardware cable will clear the code pretty easily. the yellow (airbag) clip can pop off sometimes if a seat is scootted too quickly or jerkily. the thing costs about $420 from bimmerzone, does alot of other stuff as well. there is supposedly a $30 airbag reset tool on ebay-but thats kinda iffy, as it doesn't really tell you whats going on.
some cars have 4 clips, some three. if the previous owner or shop did swap out an airbag harness, they might'v gotten a wrong part when replacing the harness. or might've just not had a reset tool. you can also just bypass the whole plug thing with little 4ohm resistors from radio shack. there might be someone else in alaska with the tool you could just drive across state and borrow.
either way, the tool will tell you what code is going off-airbag, weight sensor, or seatbelt, any of the 3 can set off the light. You have to tell the car computer to clear the code to make the car safe though. as long as you clear the code, all the airbags should still be safe and functional.
Old Sep 26, 2008 | 11:20 AM
bmwrider's Avatar
bmwrider
I am new to the website have had my 2003 MCS for about six weeks now but managed to loosen a clip behind the dash setting off my airbag light. after calling both dealers that are 2 and 3 hours away and they were telling me it would be $99 0r $57.50 to hook up and tell me what I already knew before they would touch the system. I decided to order the (B200) scan tool from obdwholesale and it gave me the code of passenger side airbag.... so I reset the light because I had already plugged the airbag in and it did reset the light. I don't know if it will give all the codes but it will help out if you know what the problem is and fix it. because if there is any fault the light will not reset.
Old Sep 27, 2008 | 12:32 AM
darksun's Avatar
darksun
I took my dealer 11 tries in about 5 months to finaly solve the problem. Makes you think...
Old Sep 28, 2008 | 09:17 AM
Candu61's Avatar
Candu61
Have used the B200 tool found I ordered it from,
http://www.obdtoolstore.com/shop/pro...3dbbd4031beb7f
Was able to read fault code and reset light so it does work, I have attached owners manual for it also. You can also find it on ebay but OBD store was priced about the same and shipping was cheaper from Hong kong to Canada than USA to Canada.
File Type: pdf
Old Nov 29, 2009 | 06:24 PM
redmini04's Avatar
redmini04
question:
By removing the pass seat and running the car for a time and then reinstalling the seat with all the connections, the air bag light is on (Obviousy since I had the seat out for some time). Now having everything reconnected (the light is still on because it has not been reset) will the passenger seat air bag function? If so I don't care about the light since I will be replacing both seats next spring anyway. Just a safety question.
Jim
Old Dec 1, 2009 | 06:56 AM
BEAVR's Avatar
BEAVR
from what I understand, the air bags will still function if needed in an accident, but, they won't function in the "smart" deploy mode that they are designed for.
probably its a safer idea to get the code reset, then, when you replace the seats in the spring, don't activate any power until after the installation.
Originally Posted by redmini04
question:
Jim
Old Dec 6, 2009 | 08:18 PM
Densmini's Avatar
Densmini
I bought the B200 tool- was very happy with it- cheaper than a single trip to the dealer!
