St. Louis MINI Club The St. Louis MINI Club Forums. Visit our club site at www.stlmini.com
Get a tiger to change it stripes
Old Jun 17, 2005 | 12:18 PM
Nails_69's Avatar
Nails_69
I have a question, I have a 2005 Mini Cooper S with Rally Strips from the factory, but I want to change its stripes. How possible or impossible is it to remove the factory stripes.
Old Jun 17, 2005 | 12:19 PM
Electron_Mike's Avatar
Electron_Mike
I believe they just peel off. I've heard having them warm helps too.
Old Jun 17, 2005 | 03:30 PM
zinful's Avatar
zinful
Stripe Removal
Heat them with a hair drier first will make it go a lot easier, then they should peel right off.
Old Jun 18, 2005 | 08:46 AM
Marek the Ultrashield Guy's Avatar
Exactly.
Or on a hot sunny day with a warm engine, they should come right off.
Let me know if you will need help.
Take care, Mark.
Old Jun 20, 2005 | 06:04 AM
prcoop1953's Avatar
prcoop1953
Speaking of removing stripes, after you do this procedure what do you do next, especially if you want to install new ones. Would claying the bonnet be best or what do you suggest. I believe I read somewhere that you do not wax, if anything you want to remove all wax.
Old Jun 20, 2005 | 04:55 PM
It would be a good idea to clay after removal.
And yes, you want to remove all wax before installation of new stripes. You want them to stick good and wax is supposed to prevent stuff from sticking to your MINI. Less chances of lifting on edges, etc. if you remove the wax (even though they will still stick fairly well).
Hope this helps, Mark.
Old Jun 20, 2005 | 07:37 PM
zinful's Avatar
zinful
After Stripe Removal
The best way to cut thru (remove) the wax is with dish washing detergent, then clay bar with a lot of lubricant, so you have a very smooth surface for the new stripes to stick to. After that I would rewax the area, including the new stripes. I use Zanio products.
Good luck,
Old Jun 21, 2005 | 09:10 AM
The best way to cut thru (remove) the wax is with dish washing detergent.
Yup, but do not use it too often, not good for the clearcoat.
And 2nd yup to Zaino. Great stuff. Ask Brad B.
Mark.
STR3T
May 23, 2016 03:27 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
Khai
Aug 12, 2015 06:20 PM
bctf1
Aug 6, 2015 12:55 PM
