FS:: Mini Madness cold air intake
Old 03-16-2016, 03:16 AM
quickcoop's Avatar
quickcoop
quickcoop is offline
Price: $150
Location (Region): Midwestern
Mini Madness cold air intake for R52 & 53 models. In good used condition. $150 shipped to the lower 48
Old 03-16-2016, 03:18 AM
quickcoop's Avatar
quickcoop
Another pic
Old 03-16-2016, 03:19 AM
quickcoop's Avatar
quickcoop
And one more
Old 03-19-2016, 11:58 AM
E-dot's Avatar
E-dot
E-dot is offline
Open to offers?
Old 03-19-2016, 03:19 PM
quickcoop's Avatar
quickcoop
Sure feel free to make offer
Old 04-13-2016, 10:10 AM
SmurfNinja's Avatar
SmurfNinja
SmurfNinja is offline
Does this have the cowl mod ?
Old 04-13-2016, 03:05 PM
quickcoop's Avatar
quickcoop
No you can either cut your panel to make the hole or just remove it
Old 08-11-2016, 04:51 AM
GregoryK's Avatar
GregoryK
GregoryK is offline
What I find interesting reading this thread is the fact that no one has commented on the real problem. 3, 4,6 and 8 cylinder 4 cycle engines are just a bad idea right out of the gate. They have spent years improving the bad idea. They make the bad idea more fuel recipient. They make the bad idea less polluting. The bad idea is now so complicated it is not only a nod to human persistence but a nod to human stupidity. IMHO.
I had a 69 mustang and when I took it to the shop the mechanic used to fight to see who was going to work on it. That car was reliable, fast, light and IMO we should have put our energies into a new type of engine back then...but that is not the way large companies (including BMW) roll.
Old 08-11-2016, 05:03 AM
quickcoop's Avatar
quickcoop
This has been sold
Old 08-11-2016, 07:30 AM
XBarbarian's Avatar
XBarbarian
XBarbarian is offline
lolwut?
random /rant bra?
MINI_42 (07-04-2020)
Old 08-16-2016, 02:35 PM
Turbo?'s Avatar
Turbo?
Turbo? is offline
Engine wise?
Would the n16 engine and transmission mounting points be the same as an n18?
Old 09-24-2016, 01:23 PM
Drdrew229's Avatar
Drdrew229
Drdrew229 is offline
Size
Offset:42mm
Backspacing:5.31"
Bolt Pattern:4-100
Rec. Tire Size:195/55-16
Weight:22.0 lbs.
Finish:Black Painted
Construction:Steel
Old 09-24-2016, 01:35 PM
quickcoop's Avatar
quickcoop
This has been sold, thanks
Old 07-04-2020, 07:29 AM
pwilk20's Avatar
pwilk20
pwilk20 is offline
So it's been four years since I posted. Wow how time flies! Well, I did nothing with the MINI since but finally I decided to make it my daily driver. The car is now 17 years old and still has a little over 4000 miles. I changed the oil, washed and waxed it. Will need new tires, time and weather dried them out.
I noticed the AC is not cooling well enough. Probably needs a recharge.
Can I just get a can of coolant gas from Pepboys? Will it be OK to recharge a 2003 car?
Thanks.
I'm sure I'll have more questions soon
Old 07-04-2020, 07:31 AM
pwilk20's Avatar
pwilk20
pwilk20 is offline
Sorry wrong forum
Old 12-04-2020, 09:05 AM
troyegly's Avatar
troyegly
troyegly is offline
If It has been a while I would replace the valve cover just because. Ebay has some quality covers for around $50.00 I did some research (NAM) for my car and went with the Ebay special and it is just fine.
Plus replacing the valve cover is such a small effort almost anyone can do it. If you have extended miles and it's not been replaced....replace it IMO.
Tora-blitz
09-21-2016 02:41 PM
juane30m3
03-14-2016 03:45 PM
zkrpS
02-23-2016 10:31 AM
Drivetrain Products
02-18-2016 10:47 AM
Drivetrain Products
02-16-2016 11:07 AM
Quick Reply: FS:: Mini Madness cold air intake
