Not sure what part this is and if it’s ok to be loose.
Old Jan 8, 2020 | 09:41 AM
Michaelh57's Avatar
Michaelh57
My countryman is a 2012 S with 72,xxx miles.
I’ve been driving my countryman around for a while now and here lately it seems to be more lurchy. Because of this I decided to check the engine and noticed that this was loose and was wondering if it not being right could be the problem. Thank you all for your help.
Also does anyone here know of any good mini mechanics in central Florida?
Old Jan 8, 2020 | 09:43 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Yes that shouldn't be loose. Leaking air is not a good thing. Sorry don't know FL mechanics but somebody should add that info soon.
Old Jan 8, 2020 | 10:00 AM
MiniToBe's Avatar
MiniToBe
The hose is cracked and needs replacement.
I have a friend in FL, check his profile and send him a message. Not sure how far from Central FL he is. https://www.northamericanmotoring.co...3-sub3622.html
Old Jan 8, 2020 | 10:12 AM
Fly'n Brick's Avatar
Fly'n Brick
If MiniToBe's friend isn't able to assist, here is a general directory that might be of help. No guarantees on quality of service but it's a place to start.
https://www.minirepairshops.com/
Old Jan 8, 2020 | 10:33 AM
Michaelh57's Avatar
Michaelh57
So is it for sure cracked or could I just get a clamp and tighten it?
is it also okay to continue driving it or should I park it until I get it replaced? Does anyone know what the part is called?
Old Jan 8, 2020 | 11:45 AM
Minnie.the.Moocher
Look on Realoem.com for part numbers and names. If it was mine, I'd buy some self sealing silicone tape (amazon, homedepot) and wrap it until I could get it fixed.
Old Jan 8, 2020 | 01:46 PM
2014 MC's Avatar
2014 MC
It looks like the intake tube, so it is sucking, not pressure. Basically leaking in dirty air bypassing filter and some sensors... So yes, try not to drive it like this and do the temporary fix mentioned as much as possible. Source the part per MTM advise :-).
Old Jan 8, 2020 | 06:44 PM
Michaelh57's Avatar
Michaelh57
I ordered the part thank you all for your help
is this a fix that I can do at home, I noticed some wires connected to it, or do i need to take it somewhere for them to replace it?
Old Jan 9, 2020 | 05:57 AM
MiniToBe's Avatar
MiniToBe
It can be done at home.
Old Jan 9, 2020 | 07:21 AM
Michaelh57's Avatar
Michaelh57
Do I need to disconnect the battery before disconnecting the wires or is it ok to leave hooked up?
Old Jan 9, 2020 | 07:24 AM
MiniToBe's Avatar
MiniToBe
Personally, I'd leave the battery connected.
the chance of frying the FRM module is far worse than getting a check engine light, which you could easily clear.
Old Jan 9, 2020 | 02:34 PM
Michaelh57's Avatar
Michaelh57
Ok thank you all for your help
Old Jan 10, 2020 | 05:50 AM
iwashmycar's Avatar
iwashmycar
Its a pretty quick fix. Just loosen the band clamps at each end, pull up on the two metal clips that hold the hoses on each side, and pop off the wiring looms that are just push-fastened to the sides of the tube. Reinstall reverse.
Old Jan 11, 2020 | 01:46 PM
Michaelh57's Avatar
Michaelh57
I replaced the part and everything is going great. Thank you all for your help I appreciate it.
Old Feb 3, 2020 | 02:49 PM
bro_hof's Avatar
bro_hof
Mine broke this weekend at 132k, same exact spot. I'll be ordering mine soon. In the meantime I just removed the bad part of the pipe and banded it to the remaining pipe.
Old Feb 6, 2020 | 01:02 PM
Yep, dont drive damaged, make sure its sealed up and no loose rubber, I dont want to see things get sucked into that turbo.
MiniToBe
23
Aug 6, 2019 04:37 PM
zoomincoop
18
Aug 9, 2018 08:04 PM
Flyboycoy
14
Sep 24, 2015 06:32 AM
csjolin
Suspension
Jan 22, 2013 09:19 AM
beauxgoris
Feb 27, 2012 02:54 PM
