R60 2012 Countryman S peekaboo game
Old Jun 24, 2019 | 01:05 PM
MiniToBe's Avatar
MiniToBe
I just picked up a nicely optioned CMS from the auction in Michigan. The only thing they mentioned is that it wont start. I have few theories but will wait until i take possession of the car, hopefully tomorrow.
Old Jun 24, 2019 | 01:15 PM
leshrak's Avatar
leshrak
Good luck
how many miles on it?
Old Jun 24, 2019 | 01:19 PM
MiniToBe's Avatar
MiniToBe
it has an awesome 107k miles of happiness lol
Old Jun 24, 2019 | 09:33 PM
Dumbledore's Avatar
Dumbledore
Just curious, how much did you pay? Does it turn over?
Old Jun 24, 2019 | 09:43 PM
MiniToBe's Avatar
MiniToBe
Not sure yet. I'll take possession of it tomorrow hopefully. Anything can be fixed and I got parts N18 and a good N18.
Old Jun 27, 2019 | 02:03 PM
MiniToBe's Avatar
MiniToBe
What a day...had to call back and forth with the broker, auction, and transporter to finally get the car released. It was loaded on the truck today and hope to get it before the weekend
Old Jun 27, 2019 | 02:39 PM
MrGrumpy's Avatar
MrGrumpy
Right on.... keep us posted
Old Jun 28, 2019 | 01:07 PM
MiniToBe's Avatar
MiniToBe
This is first impression photos...Later today, I will check if the timing is correct IF the crank actually spins..I have not tried to start it, so bear with me.
Old Jun 28, 2019 | 03:20 PM
MrGrumpy's Avatar
MrGrumpy
Well I’m not an expert, but I think what’s in your hand there looks broken. Just kidding. But now that you have the valve cover off, and pieces of the guide in your hand. You should check the chain to see if it’s stretched out of spec or not. I have seen a procedure for this somewhere online, but don’t remember where. Hopefully someone else will know what to do to check that. At the least, you need new guides. Pull the oil pan and get any pieces out of there. Or say “to hell with it” and just replace the chain too while you already digging around in there as a preventative measure. Good luck. I’m following with interest to see that thing come back to life.
Old Jun 28, 2019 | 04:12 PM
MiniToBe's Avatar
MiniToBe
Yeah not a biggie lol...I love working on these cars. Instant satisfaction lol
My plan is to remove the tire and hand spin the engine to check timing. Timing chain is out of question for replacement. Oil pan will come out to fish the broken pieces.
Touching the rollers indicates no bending...fingers crossed.
Old Jun 28, 2019 | 04:31 PM
MrGrumpy's Avatar
MrGrumpy
Yeah as long as the chain is still ok, replace the guides and it will go for a good while still. But, it may or may not have anything to do with it not starting. Have you tried to pull any codes?
Old Jun 28, 2019 | 06:51 PM
MiniToBe's Avatar
MiniToBe
There is no need to read codes because the battery was dead and I'm pretty sure I'll have more codes that may not pertain to issue...The way I handle this type of situation is simply check the mechanical parts make sure the basis is correct, like the timing. looking around the engine for loose connections and such. In this case, here what I found: for some reason the tensioner got stuck/seized causing the upper rail to break resulting in timing going crazy. after we replace these components, then we can try to start the car and pull real codes. So far, the rollers seem tight, so I'm optimistic.
Old Jun 29, 2019 | 06:46 PM
MiniToBe's Avatar
MiniToBe
I spend some time on the car and happy to report it is running and driving again
Set the timing.
old tensioner
seized tensioner on the left, then 78mm tensioner, then 82mm tensioner on the right.
after everything was reset mechanically.
no CEL
Old Jun 29, 2019 | 07:16 PM
dmath's Avatar
dmath
Congrats. That's a great outcome.
Old Jun 29, 2019 | 07:23 PM
MiniToBe's Avatar
MiniToBe
Thank you my friend not only that, I got a nice tan too lol (started around 8 and finished a little after 2)
Old Jun 29, 2019 | 08:37 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I'm always impressed with your skills at these MINI resuscitation projects. Couple of thousand miles closer and I'd be bugging you all the time to fix our MINIs. Hopefully you make some big bucks on this one.
Old Jun 30, 2019 | 12:32 PM
MrGrumpy's Avatar
MrGrumpy
That’s awesome! Good to see another saved an running again! Nice work!
Old Jun 30, 2019 | 12:43 PM
MiniToBe's Avatar
MiniToBe
Thanks for the kind words...I can always receive transport deliveries
Old Jun 30, 2019 | 12:44 PM
MiniToBe's Avatar
MiniToBe
Yup...I'm glad not too many people know how to work on them lol....timing chain all it took! Oh and an alternator
Old Jun 30, 2019 | 10:30 PM
MrGrumpy's Avatar
MrGrumpy
Right on. That’s a heck of a deal, if you wanted to flip it for a quick profit, or keep it, and now you have nice R60 to add to the stable. Looks like a net positive either way!
Old Jul 16, 2019 | 11:11 AM
MiniToBe's Avatar
MiniToBe
final update:
I got the new timing chain kit last week and had it replaced in half a way...under the sun
today, the car received a PA state inspection
waiting on the title to post it for sale
Old Jul 28, 2019 | 01:16 PM
MiniToBe's Avatar
MiniToBe
https://www.northamericanmotoring.co...ml#post4485096
Old Aug 6, 2019 | 04:31 PM
Jwanck11's Avatar
Jwanck11
Wait! You are in PA??? What part of PA? I am just above Philadelphia.
Great work and god luck with the sale!
Old Aug 6, 2019 | 04:37 PM
MiniToBe's Avatar
MiniToBe
I'm in NE Philly thanks for the wishes
praecurvo
29
Jun 8, 2013 11:20 AM
Phx JCW
May 18, 2012 05:17 PM
angryrabbit
Southern California
Feb 28, 2012 02:59 AM
Jun 27, 2011 01:58 PM
