R59 JB+ and your roadster?
Old Apr 9, 2014 | 11:40 AM
silvrevo's Avatar
silvrevo
Have any of you guys put the simple JB+ tune on your roadsters?
I'm wondering just how close a S model would be power wise to a JCW.
I guess you can JB+ your JCW too just have it dialed back some.
I'm either leaning towards a used S model and mess with it,, or just do a JCW flavor and leave the car alone,,,,,,,,haha yea it is tuff to do.
Besides that LONGGGGGG thread made by Terry , I haven't seen much of any ecu tunes on this Roadster section.
Anyone care to share that would be great!
Old Apr 9, 2014 | 07:51 PM
yetti96's Avatar
yetti96
You haven't seen much because there is really nothing different. Same engine and similar chassis.
Old Apr 9, 2014 | 07:53 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've installed a coupe JB Modules on Roadsters and they worked just as well as on the hardtops. The engines and trans are all the same so it doesn't matter it will work just as well on both.
Old Apr 10, 2014 | 08:46 AM
silvrevo's Avatar
silvrevo
Okay,
Just wanted to see who has done it on the same platform im looking at,, the roadster.
Old Apr 10, 2014 | 09:05 AM
yesti's Avatar
yesti
Originally Posted by silvrevo
Okay,
It'll give you almost as much as a JCW. For way less price. Platform is not important, engine type is important. You should do it :-)
Old Apr 10, 2014 | 12:25 PM
TG.'s Avatar
TG.
I thought there were a few engine differences on a JCW engines other than just software tuned to 208? Am I wrong?
Isn't the transmission slightly different too?
And I'm not talking about the rest of the external components such as brakes, different exhaust, IC, etc...
Old Apr 29, 2014 | 09:09 AM
whoneyc2's Avatar
whoneyc2
I personally installed this as well. Did make a good bit of difference. Some caution however, it can possibly throw an O2 fault and possibly go into 'limp mode'. As it did on mine. Did some more research and learned if you're running through the gears pretty hard and heat engine up a good bit, this can happen. Simple fix, pull it off and run it through the gears as close as you can to 5,000 rpm.
Also it's adjustable, so you can open it up and twist the **** back some if a fault is thrown right away.
I removed mine, just to get the fault out, and will probably keep it out until after MOTD. I don't wanna mess it up before I get there. Lol.
Old Apr 29, 2014 | 10:45 AM
Coop-a-Loop's Avatar
Coop-a-Loop
What 'fault' did you get? Did you get a 'code' number. Are you sure it was the JB+? Just curious. thanks
Old Apr 29, 2014 | 07:50 PM
whoneyc2's Avatar
whoneyc2
In all honesty, I don't know what the code was. I took it to dealership and had them look at it, without thinking through what could be wrong. They came back saying it was an O2 sensor thing, saying it was getting too much air. Said the chip was the issue.
Whether they were right or not... I dunno. I'm going to give it another go here soon. My expertise in cars is currently limited to those with carburetors in them, not computers. I'm learning though.
Old Apr 30, 2014 | 06:38 AM
Poderes1's Avatar
Poderes1
I had a 'fault' code on my N18 JCW as well. The check engine light wouldn't come off after I removed my JB+. Took it to the dealership and they said it was a software glitch. They fixed it and the check engine light was gone. Was wondering what would cause it as well
Old May 21, 2014 | 11:13 AM
whoneyc2's Avatar
whoneyc2
I've done quite a bit more digging around since my last post. It actually wasn't my JB+ that threw the fault. I had put an intercooler muffler delete pipe in my car and the top hose had come partially off under boost pressure. I noticed it, fixed it, and was able to replicate the O2 fault proving that was the issue. Since then, i put the factory one back on, re-installed the JB+ and have had zero issues.
Old May 21, 2014 | 01:53 PM
Coop-a-Loop
Thanks for following up on your issue. Good to know it wasn't the juice box.....
Now enjoy the boost!
OutMotoring
Nov 16, 2015 07:04 AM
Oct 1, 2015 12:13 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
