R56 No power to fuel pump
Old Mar 1, 2025 | 07:34 PM
billburleson's Avatar
billburleson
I'm working on a friend's 2013 R56 and I have no power to the fuel pump. I have checked the fuse and the relay is good but it seems that when I check for continuity between pin 3 at the relay plug and the white/blue power wire at the fuel pump plug I am showing continuity. When I jumped 5 to 3 I showed power at all 6 wires at the fuel pump plug. I'm thinking I have a wiring issue somewhere, can anyone help me with this?
Old Mar 3, 2025 | 12:24 PM
Hello, This shows you the relays and locations to check. I would also check the fuel pump wires in the pump area. I dont have the full wire diagram. Usually by the pump or the pump is the problem.
https://www.northamericanmotoring.co...-best-fix.html
https://www.northamericanmotoring.co...-location.html
https://www.northamericanmotoring.co...fuel-pump.html
Bumme56
Sep 2, 2025 05:29 PM
R53Orlando
Oct 25, 2022 08:43 AM
2007MiniCooperS
Aug 19, 2020 07:50 PM
DrakeB
Feb 20, 2019 12:07 PM
Chey Horton
Feb 2, 2019 11:46 AM
