R50/53 No power to fuel pump
Hey guys, first time posting a question. My 2006 mini R53 just quit with no codes. Was running fine. I am aware that fuel pump and fuel pump relays are a known issue. Mine has about 100k Miles on it. I decided to just replace the fuel filter and fuel pump anyway. Still would not start. I then replace the fuse block as mine has the relay integral to the fuse block. Still will not start.
Any ideas?
thanks
Any ideas?
thanks
Fuel:
Can you hear the fuel pump running when you first turn the key?
Have you checked the pressure at the rail/shader valve?
The fuel filter can also be a challenge (for some) when replacing = Not sealing correctly.
May want to pop the back seat and take a 2nd look?
No fuel pump running
checked the fuse inside the car, it has 12v on one side. appears nothing is triggering the fuel pump relay. when the key is in the on position, i get about 1.5v on the 15amp fuse F03 on engine bay fuse block. very puzzling.
Try releasing pressure at the valve on the end of the fuel rail. Trapped air can prevent starting. I don't know if this is a problem after replacing the fuel pump but it's worth a shot. Have a thick towel/rag handy so that fuel doesn't go everywhere.
Hi guys,
double checked the filter housing install. I pulled the plug on the pump and applied 12v directly and the pump operated properly.
I checked the codes and getting P1692. Will not clear. I also removed the battery, had it checked and reinstalled with a full charge. According to other threads, it is not clear to me how to diagnose the P1692 code. Seems the ECM is not allow the car to fire.
Any other help would be appreciated. really don't want to have it towed to the dealer.
For P1692, the Bentley manual mentions the throttle body and the supercharger. Maybe check the throttle body connector. For the supercharger, make sure the belt is in good condition and properly tensioned and the the by-pass valve can open and close.
This is a long shot but if our cars have an inertia switch it would be worth 2x checking that it didn't get tripped..
lol back in mY thunderbird ( mn12) days me and my buddies did it to each other constantly, all we had to do was slap the back 1/4 above the wheelwell and it was enough to trip the switch and cause no power to tge fuelpump because it would trip the switch THAT easily.
it seems his fuelpump isnot being told to turn on.. this actually sounds like a bad ecu if it were my guess.. if it just died randomly, new pump ect still no power to the pump. I've read a few posts where this were the guys exact problems and symptoms and it was ecu..
Do you have inpa ? Anything that can connect to the ecu to see if its functioning correctly? I wouldn't know what to look for exactly but if you can't connect at all to it , it might be a start..
Any ideas?
thanks
Any ideas?
thanks
P1692 from Bentley Junior ( ):
Tl;dr:
Throttle body (EDR) check to make sure it's plugged in then perhaps swap for known good one
Crankshaft pulley (very common)
Lopanda
Dec 23, 2024 07:11 PM
Hairy W Bush
R55 :: Clubman Talk (2008+)
Mar 29, 2022 01:10 PM
zapola6
Mar 24, 2015 09:24 AM
early_apex
Off-Topic :: Autos
Aug 31, 2005 10:09 AM
