R57 Remove subframe mini cooper s
Mar 3, 2022 | 11:48 AM
In order to remove the subframe from a 2014 r57 s do i need to do anything with the exhaust?
Mar 3, 2022 | 01:18 PM
Front or rear? Regardless, the exhaust goes under both subframes, so to remove either front or rear subframe, you will have to lower the exhaust.
Mar 3, 2022 | 02:22 PM
Front, I cant seem to find a good video for removing subframe do you know of any?
Mar 4, 2022 | 03:35 AM
What are you looking to do? Some tasks can be done just by loosening it a bit.
Mar 4, 2022 | 09:48 AM
I was trying to get to the rear arm bushing, sway bar bushing and remove control arm
Mar 7, 2022 | 12:30 PM
Heres a video that might give some pointers
Jul 26, 2022 | 04:26 PM
Is it possible to remove the front exhaust clamp without a special tool. I saw in a video a pair of pliers that instead of contracting when squeezed expands but i cant find one in any stores in LA wondering how else its done then
Jul 26, 2022 | 04:32 PM
Reverse pliers.
also known as bow opening pliers.
amazon or harbor freight.
where in LA are you.
Jul 26, 2022 | 04:36 PM
Im in bh, i went to Harbor Freight earlier but i didnt know the name of tool so i went to automotive and just looked for something that reminded me of it but didnt see it. Let me try that name.
Jul 26, 2022 | 05:42 PM
Jul 26, 2022 | 05:47 PM
Jul 26, 2022 | 09:49 PM
Is it the long ring pliers?
Jul 26, 2022 | 10:25 PM
Quote:
Originally Posted by
kromerok
Yes, the long pliers, that is what I used to open and install the olive connector.
Jul 26, 2022 | 10:39 PM
Remove the bolt, and use the reverse pliers to spread the clamp.
Jul 26, 2022 | 11:07 PM
Jul 27, 2022 | 03:48 AM
I’ve removed that clamp with two screw drivers wedged in between the ears
Jul 27, 2022 | 09:05 AM
njaremka
That works too, but using screwdrivers to reinstall is kinda awkward.
Jul 27, 2022 | 09:12 AM
TVPostSound
I just man-handle it to reinstall
Jul 27, 2022 | 09:17 AM
I bought the recommended part but will try to do it without it shortly to at least get it off.
Jul 27, 2022 | 10:32 AM
njaremka
Its easier on a 2nd gen, a 3rd gen its high up.
Jul 27, 2022 | 05:08 PM
I successfully removed the clamp with needle nose pliers waiting on lca and sway bushing so i will have tool to reinstall when done. Does anyone know what kind of shop would have a press to remove and install the lca bushing is it easy to do at home?
Jul 30, 2022 | 12:46 PM
Anyone know where i can get the torque specs for the subframe parts so i can start to reinstall?
Jul 30, 2022 | 01:18 PM
Ended up cutting out the old bushing and jerry rigging a threaded bolt with two washers to press in new bushing used powerflex bushings
Jul 30, 2022 | 03:35 PM
PM me your email
ill send you a newtis.com invite.
Jul 30, 2022 | 03:47 PM
