R57 Remove subframe mini cooper s
Old Jul 31, 2022 | 05:25 PM
  #26
kromerok's Avatar
kromerok
I have a login for it, I have never really been good at using it tho. I'll check again hopefully ill figure it out. Also do any of the parts im torquing need to be done under pressure?
  #27
kromerok's Avatar
kromerok
ill grab one hope it doesnt take super long to arrive.
Old Jul 31, 2022 | 05:37 PM
  #28
TVPostSound's Avatar
TVPostSound
Torque all suspension replaced parts with the car in neutral suspension travel.
  #29
TVPostSound
Tunershop? Germany to me in California in 3 days!!
Old Jul 31, 2022 | 06:21 PM
  #30
kromerok's Avatar
kromerok
Im sorry I don't know what neutral suspension travel means. Im more of a youtube mechanic, I follow directions quite well.
Old Jul 31, 2022 | 06:22 PM
  #31
kromerok's Avatar
kromerok
Thats not bad at all, ill wait then. The last thing i need to do is tighten up the rear lower camber a shop told me it was loose
Old Jul 31, 2022 | 07:04 PM
  #32
TVPostSound
The angles at which the suspension components would be if sitting on wheels.
Old Jul 31, 2022 | 07:31 PM
  #33
kromerok's Avatar
kromerok
Would this be for the subframe also or just things like the sway bar and control arm?
Old Aug 1, 2022 | 10:11 AM
  #34
kromerok's Avatar
kromerok
Also, if im changing the sway bar bushings do i need circolight? If yes is there a substitute I should be able to find locally?
Old Aug 1, 2022 | 10:48 AM
  #35
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
This stuff is pretty much the same as provided by all the poly bushing manufacturers:
Amazon Amazon
Also, if you are replacing the bushings with poly versions, they should move well enough that you shouldn't need to torque the suspension under load.
Old Aug 1, 2022 | 07:39 PM
  #36
kromerok's Avatar
kromerok
Using this pic as an example would bolt # 12 be done under done under load while say bolt # 8 and 14 dont need to be under load? What about bolts 11
Thx
Old Aug 2, 2022 | 03:27 AM
  #37
njaremka's Avatar
njaremka
Alliance Member
Community Builder
#8 is a ball joint, load or no load won’t matter. It will be easier to line up without load, then torque it down. Same with #14 and 15. #11 will be MUCH easier with the subframe removed from the car. #12 is a hard frame mount, so also better done with no load.
Now that I’m looking at it, there really are no bolts that need to be torqued under load in the front.
Old Aug 3, 2022 | 07:04 AM
  #38
kromerok's Avatar
kromerok
Are these the torque settings for the subframe itself?
​​​​​​Front subframe
Front Bolts 100nm (74lb) 2 front
Rear Bolts 100nm (74lb) 6 rear
Control Arm 59nm (44lb) +90 degree turn 2 sides?
MotorWorf
R55 :: Clubman Talk (2008+)
Apr 29, 2013 12:18 PM
seattlent
Feb 17, 2013 01:17 PM
antsmini
Aug 19, 2003 10:06 AM
