R57 need help with an icon/chime warning:
Old May 19, 2011 | 08:08 PM
petegtsv10's Avatar
petegtsv10
When I put the top down on my wife's 2010 MCS I get an icon in the tach area. It's a closed padlock with a car icon (top down) right below it. This is accompanied by a series of warning chimes. I can't find an explanation in the manual. We've looked over things that we see as lock related, but no luck. What are we missing here?
Old May 20, 2011 | 03:01 AM
Derepente's Avatar
Derepente
Perhaps the latches are not completely down in the boot.
I assume you do get to where the top does open completely. These latches I refer to are the ones that you have to open to release the top part of the boot where the shelf is.
My gym bag regularly catches the latch handle. So if I'm not careful, i sometimes open or raise the latch handle when removing my bag.
Check and see... Let us know.
Cheers!
Old May 20, 2011 | 06:15 AM
MiamiGuitarMan's Avatar
MiamiGuitarMan
Off the top of my head I don't remember what that icon means but I do know I saw it in the owner's manual when I read through it after getting my mini.
If you have your owners manual, in the back there is a section that lists and shows most of the icons warning lights and explains what they mean. That particular one is in there.
Old May 20, 2011 | 07:08 AM
petegtsv10's Avatar
petegtsv10
Maybe I'm just not seeing it, but I don't see an explanation of this icon in the manual.
Old May 20, 2011 | 08:35 AM
gaylon's Avatar
gaylon
Will the top respond to the button? Is it still going up and down? Does the chime stop in either of these conditions (up or down)?
On my '11 MCSC, I had a sensor fail and the top was stuck in the almost down position. The icon you mention appears, which I believe means that the top has failed to close and lock down, and the car chimed incessantly at any speed over 25 mph. Also, the rear hatch would not open. I had to take it in for repair. Thank god for the warranty.
Old May 20, 2011 | 11:54 AM
petegtsv10's Avatar
petegtsv10
Top goes up and down. The icon/chime happens only with the top down and driving.
Old May 20, 2011 | 12:09 PM
gaylon's Avatar
gaylon
Take it to the dealership. There is a sensor that tell the car that the top is all the way down and locked. It is malfunctioning.
Old May 20, 2011 | 01:27 PM
peeti's Avatar
peeti
Or you are not going all the way on open or close.
Old May 21, 2011 | 03:27 PM
orangecrush's Avatar
orangecrush
X2 or it’s not completely down... I used to have this problem all the time with my cabrios. It looks down but there was always something in the way for the full travel.
Old May 29, 2011 | 03:08 AM
Frenchy2004's Avatar
Frenchy2004
If you are close to one take it to a dealer. I took delivery of 11 and it was doing the same thing, except it would not go back up afterwords. They had it for a few days before they figured out which switch was bad. The crappy thing was that it got stuck down on me over 300 miles away from home, and the manaul closing procedures can be a bit of a hassle. Be careful if you ever have to use the manual crank to close the top.
user 56789
Jan 10, 2016 12:27 PM
user 56789
Nov 30, 2015 03:53 PM
R3411y
Nov 23, 2015 01:10 PM
user 56789
Sep 14, 2015 12:57 PM
