R56 Shift KnObsession
Old Apr 23, 2007 | 08:30 PM
  #51
lava's Avatar
lava
Originally Posted by Robin Casady
You mean veneers for putting over the Piano Black, Brushed Aluminum, etc.?
I was thinking more of carved solid wood in the same shape as the stock pieces - but perhaps a nice mini logo in relief on the face..
Old Apr 23, 2007 | 10:37 PM
  #52
Robin Casady's Avatar
Robin Casady
Uh huh, hand carve it with chisels, or buy/build some sort of large CNC carving machine? Do you think the MINI dash is solid wood? I suspect it is stamped steel with a veneer applied. Might even be 3M's pressure sensitive veneer (peel-and-stick). Or, the dash could be some sort of composite with veneer, but I would bet a lot of money that it isn't carved out of solid wood.
So, I suspect there would not be room for a carved wood piece there. Anyone take the dash apart? What are the English Oak/Piano Black/Brushed Aluminum/Checkers/etc. made of? How thick are they? What is behind those panels?
Old Apr 24, 2007 | 07:47 AM
  #53
lava's Avatar
lava
If you did cnc then you could crank them out faster - still a lot of hand finishing. In the end even if it was all by hand and obscenely expensive, you would still sell them because they would be so beautiful.
If it is veneer it is a very curvy compound surface - not so sure it would be easy to veneer. And veneer is never going to have the same appearance as a solid piece.
Old Apr 24, 2007 | 08:50 AM
  #54
Doug W's Avatar
Doug W
Here; I'll sell you this CNC machine. A friend of mine is "supposedly" buying it from me; been making payments on it for nearly a year now.
Probably doesn't have the spindle speed required for woodworking, though.
Old Apr 24, 2007 | 09:04 AM
  #55
bamatt's Avatar
bamatt
Robin if you could come up with a black & white checkerboard **** using the resin somehow that would be to die for
Old Apr 24, 2007 | 09:58 AM
  #56
Robin Casady
My car isn't here yet. Can I take your's apart to see if it is feasible?
Old Apr 24, 2007 | 10:01 AM
  #57
Robin Casady
I have some ideas about that.
I should definitely be able to come up with a wood **** that has a checkered inlay of ebony and holly. May also be able to do something in plastic.
Old Apr 24, 2007 | 10:58 AM
  #58
bamatt's Avatar
bamatt
I am interested in a black & white checkered **** (wood wouldn't work for me) as I have a whole B&W checkered theme going on w/my MINI so keep me posted
Old Apr 24, 2007 | 11:08 AM
  #59
Skye2's Avatar
Skye2
Very very nice Robin!
PsychoRallye
21
Feb 17, 2019 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
02miniSguy
Nov 17, 2015 10:29 PM
MINI Stupor
Oct 1, 2015 11:36 AM
bahman
Sep 30, 2015 01:59 PM
