R56 Things you didn't know about your R56 MINI
Old Aug 12, 2008 | 05:24 AM
  #1351
x uh oh x's Avatar
x uh oh x
Originally Posted by LynnEl
After the latest software update, the "Arrow Display" function on the navigation is no longer available. (I'm referring to the one that displays an arrow only, without the map). Personally, I don't use that feature, but you may want to know.
Also, this is in the owner's manual, but I don't like it. While the Dynamic Route mode is on, the navigation will automatically reroute if there is a traffic problem, but will provide no information on the screen about it. With it turned off, however, the nav will display what the obstruction is, where it is, how long the delay is, how it plans to reroute you, and give you the option to reroute. Thus, to me, "Dynamic Route" sounds good, but isn't.
That's odd...I just got the new NAVTEQ disks in DEC 07 for my '07 MCS. I get the dynamic routing (forgot I could turn it off), and it will give me both screens - it will display the obstruction info, then the map, then the re-route. It's annoying, for sure, but....? Hm. Luckily we don't get enough traffic here to work that function much...
Old Aug 12, 2008 | 07:00 AM
  #1352
toolazyforalogin's Avatar
toolazyforalogin
I didn't know that there are slides on the seatbelts that need to be slid up to sit directly below the clip for the seat belt. This is to stop the clip from getting stuck between the seat and the door. Guess I know what they were for on my last car too.
Old Aug 12, 2008 | 07:07 AM
  #1353
daffodildeb's Avatar
daffodildeb
You likely did. I've had them for the past 15 years or so, albeit on BMWs. Can't speak for other makes.
Old Aug 12, 2008 | 10:20 AM
  #1354
Loony2N's Avatar
Loony2N
Originally Posted by Minidrivr
Any other changes, like maybe the POI search function in that update? When did you get the update?
I haven't tried the POI but I doubt it's been changed. I got the update about 2 weeks ago.
Old Aug 12, 2008 | 10:27 AM
  #1355
Loony2N's Avatar
Loony2N
All I get is a voice saying "There is a disruption on your route. Your route is being recalculated." Problem is, the disruption is often cleared up long before the information is updated, so I don't want it to recalculate anything without me having the option of cancelling or altering it.
Old Aug 12, 2008 | 12:58 PM
  #1356
Sowellman's Avatar
Sowellman
Can you explain to me what dynamic routing is supposed to do. I have no clue what makes it different from the other choices.
Old Aug 12, 2008 | 01:52 PM
  #1357
Birdman's Avatar
Birdman
Dynamic routing just means it will utilize the Traffic information. So if the Dynamic option is checked off, then system will automatically re-route you around a problem area (accident, construction...). If it is unchecked, it will not re-route you. They should re-label it "Traffic routing" or "Traffic Avoidance" or something....
Old Aug 12, 2008 | 02:55 PM
  #1358
TheBigNewt's Avatar
TheBigNewt
i didn't know that if you insert the metal key (that comes out of the fob) into the door lock you can roll up your windows and close the roof without getting in the car. Can't do it with the fob itself, that will only roll them down.
Old Aug 12, 2008 | 03:23 PM
  #1359
pilotart's Avatar
pilotart
The metal key works both ways, it will also roll down the windows and vent the sunroof panels just like the fob.
Although the standard fob will not close windows (or sunroof) with lock button, won't Comfort Access fob do it?
Or is it just the black button that does the complete close and lock.
Old Aug 12, 2008 | 07:40 PM
  #1360
Sambo99's Avatar
Sambo99
Thats odd - My fob wont do either open or close... I generally get in the car and quickly open the sunroof to vent the hot air (I tried the fob, but for some reason it didnt work - will ask the car dealer at the next service)
Old Aug 12, 2008 | 07:45 PM
  #1361
pilotart's Avatar
pilotart
This excellent summary needed repeated
Originally Posted by mwittstock
• when you enter and exit the car not only do courtesy lights come on in the driver and passenger footwells but there are also lights on the bottom of each door that illuminate the area around the car. also the lights don't instantly com on, they fade on and off for a cool effect.
• you can put stuff in the vertical boot storage nets. apparently the dealership didn't know this either as they attached one backward.
• i didn't know it had those mood lights inside the armrests.
• i didn't know the fm radio will list the song and artist information for some stations. i admit i wasn't up to date that many radios have done this for years.
• i had an incident today when apparently i accidentally hit the lock button at the same time as the unlock button. i was temporarily locked out--got in through the passenger side. here's the thing i learned: my service advisor says there's a "pause" built into the lock in case this happens. wait a few seconds and the system will reset itself.
• there is a small key inside the round r56 disk-key. it reseases with a little button. it seems it's not meant for a wallet but is made to remain part of the disk.
• if you leave the heated seats on when you turn the car off - when you return and restart the car, the rfid chip embedded in the will not only remember what setting you set it at but also if you prefer celcius or farenheit, or litres per 100 km consumption vs. mpg.
• and if your wife/significant other/kid/dog gets in and uses the other key, all the settings they had set will be retained.
• also, driving lights stay on regardless of high or low beams.
• when you are riding with your wipers on, and you come to a stop as at a traffic light, your wipers slow to intermittent automatically, then resume wiping once you start off again. thats what they did from the medium setting at least - i did not try the fast setting. and, no, i don't have rain-sensing wipers.
• the speed-sensitive volume adjustment on the radio (at least the hifi) is itself adjustable
• you can have different bass/treble/balance/fader settings for fm, am, cd, and aux. presumably the ipod adapter and cd changer would keep their own settings.
• you can access some obc settings from the radio (things like time, units of measure, read the fuel economy, etc.
• if you have the bluetooth option when someone in your phone's phonebook calls you thier name pops up on the radio screen.
• when you arrive at your destination and shut off your mini, when you get back in and start up again the cd player starts the last track at the beginning.
• i didn't know that (if programmed properly) a quick tap on the turn signal will flash the turn signal 3 times, then stop. great for lane changes, instead of holding it down. i love this!
• its snowing, i have the front wiper on, rear wiper off. i shift into reverse when i am parking, and the rear wiper comes on by itself and runs until i take the car out of reverse! handy!
• headlights adjust, and you can tell when you first turn them on if your looking at them form outside the car, my ma said they moved so they coudl adjust to the road.
• the mood lighting has 5 colors if you tap the switch. you can get in-between shades by holding the switch.
• if you lock the car with the lights on - the lights will shut off to conserve the battery (non-convenience pack cars, non-autoheadlights).
• you can retract the mirrors at speeds at up to 20 mph - however any speed above that does not allow you to retract them. however, if they are retracted, they can be extended at any speed!
• the cigarette lighter outlet shuts off when the key is out. handy if you run a radar detector--no problems if you forget to unplug it.
• when the sun shines directly on the tachometer digital display, the display changes from an led red to a liquid crystal grey. most displays wash out in direct sun .. this one becomes very crisp and clear.
• driving with the back seats down results in more road noise (a significant difference in my car).
• if you hold the unlock button on the remote down when approaching your car, the windows go down.
• when pushing the button to start the car, it's only necessary to hold it momentarily even though the starter continues 'til the engine starts.
• when your car is locked, pressing the lock button on the remote turns on the interior lights. i suppose this is to see if an intruder is inside your car or to just see inside while keeping the door locked. maybe this is pretty common but i never noticed it before.
• if you get out of the car and leave the door(s) open to hear the stereo you can turn off the domelight by holding the switch for 3-4 seconds. (and i like that there's no stupid warning noise when the doors are open and the key is on).
• push start/stop, let go and then push in the clutch and it starts. i haven't tested to see how long you can wait before pushing in the clutch and still have it start. i'm talking a lag of two or three seconds.
• press the lowercase m button on the radio, and it brings up a list of numbers. press the corresponding #'s for the station...very cool.
• there is an alternate setting for the rear seats that allows a little extra room in the boot and still lets passengers sit in the rear seat (maybe a little uncomfortably, but safely). fold the rear seat backrest forward, then pull up on the rear seat latch bar. the top part of this latch bar is where the seatback normally latches onto the rest of the car; you need to pull up on the bottom part of the bar, about 6 inches below the ordinary latch point. then latch the rear seat to the latch bar.
• you don't even have to hit the start button, just push the volume/power button and the radio fires up... along with some other lights and stuff.
• my ma told me that the boot unlock button on the remote would no longer unlock the boot because with the alarm that button is now the 'panic' button. well, if you depress it briefly, less than two seconds, it does indeed still unlock the boot. longer than two seconds and it indeed sets off the panic noisemaker
• the chrome gas door locks when the car is locked.
This (post #939 fom March 25 '08) was such an excellent summary of so many 'tips' that I thought it deserved another view in this great thread
Old Aug 12, 2008 | 10:48 PM
  #1362
daffodildeb
It might not be a defect in your car. Most posters are referring to USA-spec cars, and Australian-spec MINIs might be different. (I assume you are holding the button down long enough. In mine, it's at least 10 seconds.)
Old Aug 13, 2008 | 04:32 AM
  #1363
Loony2N's Avatar
Loony2N
Update on the Software Update
I was able to reactivate the "Arrow View" on/off option. In Set Up, under the category "Language/Units" (why there, I have no idea), I unchecked the Arrow View option, activated my navigation, went back into Set Up and re-checked the arrow view option. Now, it once again allows me to select/deselect "Arrow View" from within navigation. A kind of reboot, I suppose. (BTW, I descibed the Arrow View wrong: Actually, in that view, there is a split screen with the map on the left and the arrow on the right).
Also, I can get information on the traffic disruption when Dynamic Route is activated: When Dyanmic Route announces that a disruption is on your route (or any other time, for that matter), you can joy stick to the right portion of the navigation screen, onto the icon that is a triangle with an ! in the middle of it and it will give the specifics of the "traffic disruption."
Another cool feature of that icon is that, even with the navigation off, it will list every major and semi-major road for at least 50 miles from where you are that has a traffic problem. It tells you what the problem is, where the problem is, how long the problem is, and the direction that is affected. I think this is very usefull if you know how to get where you are going and don't need to use the navigation, but still want to see if there's any problems along the way. For example, I found out ahead of time that there is long term construction, causing a single lane closure on Route 50, between two points (which I forget), in both directions.
Old Aug 13, 2008 | 04:56 AM
  #1364
Tu13es's Avatar
Tu13es
Agreed, lots of useful tips there. Methinks this topic would make a great wiki page or something. Anyone agree?
Old Aug 13, 2008 | 07:03 AM
  #1365
Minidrivr's Avatar
Minidrivr
Everything you mention except the ability to turn on/off the Arrow display was in the nav system before the update.
Also that traffic icon on the right end of the map page turns red when there is traffic on your route.
Did you get a chance to look at the POI search function? Can you search without a category yet?
Old Aug 13, 2008 | 07:19 AM
  #1366
Loony2N's Avatar
Loony2N
I thought that may have been the case, but hadn't played with that stuff in a while.
It's the same piece of crap it was before. I would imagine the fix for that would require both a software and disk change.
Old Aug 13, 2008 | 08:23 AM
  #1367
geekswrath's Avatar
geekswrath
Confort access fob acts the sam as the regular fob. Although, I think, you can hold down the little black button on the door handle to close things up. I'll try to test this afternoon.
Old Aug 13, 2008 | 10:26 AM
  #1368
Goldilocks's Avatar
Goldilocks
Just thinking -- should this all have it's own separate thread - like Software Update?
Old Aug 13, 2008 | 12:51 PM
  #1369
pjo1966's Avatar
pjo1966
I didn't know how frustrating the voice dial would be to use. I'll speak in a normal voice throughout, but when I get to "Would you like to dial John Smith?" and I say yes there's usually a long pause and then I hear "please speak". If I don't yell "Yes!" it doesn't hear me, yet it hears me fine for the rest of the process. I am by no means a low talker.
Old Aug 13, 2008 | 03:38 PM
  #1370
Goldilocks's Avatar
Goldilocks
Ah, but you do sound like a Seinfeld fan "low talker"
Old Aug 14, 2008 | 03:32 AM
  #1371
Sambo99's Avatar
Sambo99
Ive done the looooong hold and yeppo - no window/sunroof motion. You could be right about the Australia thing though. Next MINI run I will check with the other R56 owners :P I did read somewhere that it is something that can be reset by the MINI garage peeps. Will definitely be handy come summertime here in Brisvegas.
Old Aug 15, 2008 | 04:33 AM
  #1372
Tu13es's Avatar
Tu13es
I went ahead and took that nice summary post and edited it for grammar and such to make it a little more readable. I've got it in a Google Doc in case anyone wants to make any changes.
It seems for some silly reason I can't make this editable by the public. If you see anything that could be added or changed, let me know and I'd be glad to share the doc with you.
http://docs.google.com/Doc?id=df9zkbwr_69hnz7f9ds
  • When you enter and exit the car, not only do courtesy lights come on in the driver and passenger footwells, but there are also lights on the bottom of each door that illuminate the area around the car. Also, the lights don't instantly come on; they fade on and off for a cool effect.
  • You can put stuff in the vertical boot storage nets. Apparently, the dealership didn't know this either as they attached one backwards.
  • It has mood lights inside the armrests.
  • The FM radio will list the song and artist information for some stations.
  • There's a "pause" built into the lock in case you hit the lock and unlock buttons at the same time. Wait a few seconds and the system will reset itself.
  • There is a small key inside the round R56 disk key. It releases with a little button. It seems it's not meant for a wallet but is made to remain part of the disk.
  • The keys retain settings like heated seats, C/F temperature, etc.
  • Driving lights stay on regardless of high or low beams.
  • When you are riding with your wipers on, and you come to a stop, your wipers slow to intermittent automatically, then resume wiping once you start off again.
  • The speed-sensitive volume adjustment on the radio (at least the HiFi) is itself adjustable.
  • You can have different bass/treble/balance/fader settings for FM, AM, CD, and Aux. Presumably the iPod adapter and CD changer would keep their own settings.
  • You can access some OBC settings from the radio (things like time, units of measure, read the fuel economy, etc.)
  • If you have the Bluetooth option, when someone in your phonebook calls you, their name pops up on the radio screen.
  • When you arrive at your destination and shut off your MINI, when you get back in and start up again, the CD player starts the last track at the beginning.
  • If programmed properly, a quick tap on the turn signal will flash the turn signal 3 times, then stop. Great for lane changes, instead of holding it down.
  • If the front wiper is on and rear wiper off, upon shifting into reverse, the rear wiper comes on by itself and runs until the car comes out of reverse.
  • Headlights adjust, and you can tell when you first turn them on from outside the car.
  • The mood lighting has 5 colors if you tap the switch. You can get in-between shades by holding the switch.
  • If you lock the car with the lights on - the lights will shut off to conserve the battery (non-convenience pack cars, non-autoheadlights).
  • You can retract the mirrors at speeds at up to 20 mph. However, any speed above that does not allow you to retract them. They can be extended at any speed.
  • The cigarette lighter outlet shuts off when the key is out. Handy if you run a radar detector--no problems if you forget to unplug it.
  • When the sun shines directly on the tachometer digital display, the display changes from an LED red to a liquid crystal grey. Most displays wash out in direct sun; this one becomes very crisp and clear.
  • Driving with the back seats down results in more road noise.
  • If you hold the unlock button on the remote down when approaching your car, the windows go down.
  • When pushing the button to start the car, it's only necessary to hold it momentarily even though the starter continues until the engine starts.
  • When your car is locked, pressing the lock button on the remote turns on the interior lights.
  • If you get out of the car and leave the door(s) open to hear the stereo you can turn off the dome light by holding the switch for 3-4 seconds.
  • Push start/stop, let go and then push in the clutch and it starts. This only works for about two or three seconds.
  • Press the lowercase m button on the radio and it brings up a list of numbers. Press the corresponding #'s for the station...very cool.
  • There is an alternate setting for the rear seats that allows a little extra room in the boot and still lets passengers sit in the rear seat (maybe a little uncomfortably, but safely). Fold the rear seat backrest forward, then pull up on the rear seat latch bar. The top part of this latch bar is where the seat normally latches onto the rest of the car; you need to pull up on the bottom part of the bar, about 6 inches below the ordinary latch point. Then, latch the rear seat to the latch bar.
  • You don't even have to hit the start button, just push the volume/power button and the radio fires up... along with some other lights and stuff.
  • The boot unlock button on the remote would no longer unlock the boot because, with the alarm, that button is now the 'panic' button. If you depress it briefly, less than two seconds, it does indeed still unlock the boot. Longer than two seconds and it indeed sets off the panic noisemaker.
  • The chrome gas door locks when the car is locked.
Old Aug 15, 2008 | 12:33 PM
  #1373
mslatter's Avatar
mslatter
Those two plastic circles on the inside of the boot are handles for you to pull the hatch closed without getting fingerprints all over your paint.
Old Aug 15, 2008 | 12:45 PM
  #1374
x uh oh x's Avatar
x uh oh x
OR they can be used by those people stuffed into your boot, so they can close the hatch themselves.
Old Aug 15, 2008 | 01:33 PM
  #1375
DanF's Avatar
DanF
What are these driving lights in the list above? Are those the parking lights that are clustered with the fog lights that are below the headlights?
