R56 Things you didn't know about your R56 MINI
Old Oct 18, 2007 | 10:33 AM
  #476
DARK CHILI's Avatar
DARK CHILI
Originally Posted by T-POD
I was happy to find out a carton of eggs fits perfectly tucked in between one of the triangle cargo nets and the wall of the boot. I can do a grocery run and drive frisky!! In my old car, everything just rolled around the trunk.
Funny, I thought it was for those liquor bottles.
But I did notice that the fuel gauge dims and brightens depending on the angle of the sun....cool..
Old Oct 18, 2007 | 11:18 AM
  #477
jw34's Avatar
jw34
I like how the tach changes from orange to grey depending on the sun. And to the point where numbers and letters can be half orange and half grey. I find it very legible in changing light.
Old Oct 18, 2007 | 11:58 AM
  #478
R56 Ed's Avatar
R56 Ed
I'm sure I've read this already, but just re-discovered it today
'07 MC, 6spd, in gear, and wanting to apply both brake and gas, the brake apparently kills the gas input, so all I get is brakes, just when I wanted gas, too. I haven't tried it with DSC off (I just thought of that) so that's the next thing to try. Heel & toe shifting works great, though
Old Oct 18, 2007 | 05:02 PM
  #479
Beebe's Avatar
Beebe
Silly, the liquor bottles go up front in the door wells, that's what they were designed for --- really. Don't ever drink and drive!!
Yes! Yes! I love this! To me, this is a pinnacle achievement for the human race.
Old Oct 18, 2007 | 11:54 PM
  #480
wrxdriver's Avatar
wrxdriver
see below
Old Oct 18, 2007 | 11:57 PM
  #481
wrxdriver's Avatar
wrxdriver
I wanted to do a test to see what the difference between how fast the mini speedometer said I went versus how fast my gps said I was going at that point in time.
Difference in mini mph (false speed) vs. gps mph (actual speed)
mini: 40 70 90
gps: 35 64 82
I just didnt think it was that much of a difference.
Old Oct 18, 2007 | 11:59 PM
  #482
Robin Casady's Avatar
Robin Casady
Originally Posted by wrxdriver
sI clocked the difference in the speed that your mini says its going compared to gps. While my mini said i was traveling at 45, gps says 40 mph; mini: 70 gps: 64; mini 90 gps: 82. I didnt realize that it was that much of a difference.
What wheels and tires do you have?
Old Oct 19, 2007 | 12:05 AM
  #483
wrxdriver's Avatar
wrxdriver
16 inch rims
215/40/16 ecsta spt
I know that will make a slight difference and I am going to test out with the stock 17 webspokes along with r/f. But I have always noticed that while driving on the freeway it seemed I had to take a higher mph to keep up with traffic. Ill test and post up my findings later.
Old Oct 19, 2007 | 12:23 AM
  #484
Robin Casady
16 inch rims
215/40/16 ecsta spt
O.D. 22.8"
911 revs per mile
Stock 17"
24.5"
853
You should expect a 7% increase from the stock speedo reading, which is already optimistic. You are probably looking at somewhere in the neighborhood of a 12-15% error.
Old Oct 19, 2007 | 12:29 PM
  #485
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
mini: 40 70 90
gps: 35 64 82
What makes you think the gps speed is actual speed versus what is displayed on the speedo? A GPS unit isn't 100% accurate, I'd think the speedo would be more accurate to the GPS simply because of the accuracy of the satelllites locating the GPS receiver. We have a Garmin Nuvi 360, it's accuracy is <5 meters for location and velocity is .05 meters/sec RMS
Old Oct 19, 2007 | 12:56 PM
  #486
jascooper's Avatar
jascooper
Doesn't the Dept. of Defense prohibit GPS's from being accurate to <300ft?
Old Oct 19, 2007 | 01:48 PM
  #487
ladisney's Avatar
ladisney
Not anymore. Although they can make it less accurate or even unavailable to civilians at any time. Sorta nice to know they can make it so that terrorists and other assorted bad guys can't use it to deliver weapons.
Old Oct 19, 2007 | 01:57 PM
  #488
pdoyle's Avatar
pdoyle
jascooper - You are correct that the military GPS signal is far more accurate then the civilian one but even the civilian signal has an accuracy more along the lines of 3 meters if I am not mistaken.
Old Oct 19, 2007 | 02:11 PM
  #489
jascooper's Avatar
jascooper
Selective Availability (SA)
  • "SA is the intentional degradation of the SPS signals by a time varying bias. SA is controlled by the DOD to limit accuracy for non-U. S. military and government users. The potential accuracy of the C/A code of around 30 meters is reduced to 100 meters (two standard deviations)."
source: http://www.colorado.edu/geography/gc...ps/gps.html#SA
Old Oct 19, 2007 | 02:18 PM
  #490
Robin Casady
Copyright © 1999 Peter H. Dana.
Perhaps it is a little out of date?
Old Oct 19, 2007 | 06:11 PM
  #491
wrxdriver's Avatar
wrxdriver
Regardless I doubt its off by that large of margin.
Old Oct 19, 2007 | 06:18 PM
  #492
aaoun's Avatar
aaoun
Very outdated
http://en.wikipedia.org/wiki/Global_...e_availability
Old Oct 19, 2007 | 07:03 PM
  #493
Robin Casady
If "it" refers to GPS, I think you are correct. If "it" refers to the 1999 info on GPS, I'd say it was way off.
Old Oct 19, 2007 | 07:55 PM
  #494
jascooper's Avatar
jascooper
Wow! First I was behind the times with toolkits that had no 16mm or 18mm sockets or wrenches. Now I can't paint that target on my roof without fear of being hit by a terrorist missile.
Now that I think about it my nav system always says "You have arrived." in the same exact spot every time I reach home. Right at my mailbox.
Old Oct 19, 2007 | 08:54 PM
  #495
Robin Casady
Mine also says I've arrived when I'm at the mailbox. Unfortunately, the mailbox is a long drive from the house. You have to climb up a switchback drive for an altitude change of about 400 ft. Then pass by four other houses.
I've been to places where the NAV arrival poiont was several houses off, but I think that has to do with accuracy of its address information, not the GPS.
Old Oct 19, 2007 | 11:46 PM
  #496
SimpsonGI's Avatar
SimpsonGI
That spec from the Dept of Defense is out of date. As I said, the Garmin Nuvi 360 has an accuracy of < 5 meters so it is accurate to within 16.4041 ft or 16 ft and 4.85039 inches. You can easily check the accuracy of the various units by going to the manufacturers website and finding the spec sheet for the model in question.
Old Oct 19, 2007 | 11:47 PM
  #497
SimpsonGI's Avatar
SimpsonGI
Correct.
Old Oct 20, 2007 | 08:24 AM
  #498
ladisney's Avatar
ladisney
Living in Iowa I have friends who are high tech farmers. There is a trend to what is called precision agriculture. Satellite imagery, GPS and computers are used to precisely map fields for application of fertilizer, pesticide, herbicide and seed. I don’t know all the details but they tell me that the system allows them to automatically put down only the required product where it is needed and avoid using too much or too little in any spot in their fields. They tell me the system is accurate almost row to row, that would be just a meter or so.
Old Oct 20, 2007 | 08:36 AM
  #499
r56mini's Avatar
r56mini
I keep pushing my car harder and harder and I had no idea my MCS was this fast. I just feel sorry for the people who bought 2006 instead of 2007 thinking that the horsepower increase was just 5HP.
Old Oct 20, 2007 | 01:43 PM
  #500
wrxdriver's Avatar
wrxdriver
Yeah, "it" refers to GPS.
