R56 Under body panels/splash shields/belly pan?
Old Jun 27, 2021 | 08:01 AM
Nemick's Avatar
Nemick
I have a 2011 R56 Cooper S. From what I can tell, every version of a mini has a different set-up under the engine as far as shields, covers, belly pans, etc. Can someone with a 2011 R56 Mini Cooper S (Hatchback) confirm what my car should have under the engine bay, if anything? Right now, my car has absolutely nothing under the engine/sub-frame area, but I do see various mounting points for something. Please help and post some pics if available.
Thanks in advance
Neil M.
Old Jun 27, 2021 | 09:02 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The only R56 Mini that came with an engine undertray is the GP2. It can be retrofitted to your car:
https://www.ecstuning.com/b-genuine-...51757330566kt/
Old Jun 27, 2021 | 09:51 AM
thefarside's Avatar
thefarside
I've owned a 2007 & a 2013, neither had a splash pan under the engine. There is a small splash shield under the right front corner
Old Jun 28, 2021 | 04:34 AM
Yoshimura 1's Avatar
Yoshimura 1
I just removed that little splash shield on my car to put on another.
Old Jun 28, 2021 | 05:26 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Below is the standard R56 looks like under the engine:
The OEM "splash shield" is that small triangle shaped piece next to the oil pan, on the left side of the picture. The GP2 shield will cover the whole area from the bumper back to the middle of the subframe cross member, just in front of the cat.
Old Dec 22, 2021 | 10:14 AM
Just an update these back in stock again
https://www.ecstuning.com/Search/Sit...51757330566KT/
Old Jan 6, 2022 | 06:30 PM
bagwell's Avatar
bagwell
Serious question, won't this increase engine and turbo temps?
Old Jan 7, 2022 | 03:31 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
It will actually increase airflow through the radiator and engine bay, and help with aerodynamics under the car. Due to the benefits seen from having an undergrad, I believe Mini decided not to include n under tray in the US due to cost cutting. All 3rd gen models have one…
Old Jan 10, 2022 | 07:53 AM
+1 ^^
Old Feb 2, 2022 | 10:30 AM
bagwell's Avatar
bagwell
ordered from ECS and installed on 11 MCS
Old Feb 2, 2022 | 10:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Nice!
That front tab actually goes under the bumper lip, so it can hold up the front edge while you secure the two rear clips. When I pull mine off, I'll slide it back in under the bumper lip, secure the two rear fasteners, then go around and get the rest.
Old Feb 2, 2022 | 01:42 PM
Yep that tap goes up on top and then the pan slides fwd a bit.
Old Dec 10, 2024 | 09:14 PM
pkgmSu2000's Avatar
pkgmSu2000
Shocking! BMW offers all the innovative tech and over-engineering on $30k car, but can’t include with car stock from factory a simple plastic undertray for protection from road debris. FUBMW!
Old Dec 11, 2024 | 09:32 AM
We see the same thing with other makes here under 30K. The VW ones are fabric and are very little protection. Most are junk on the VAG side. You have to get a Porsche or high end Audi to get them. Not just plastic, but Actual aero plastic. We had a Porsche 911 RS in the shop for scan next to my MINI and the panels on my MINI are better then what's on the Audi R8 which was also here for coilovers. Their panels were not ridged all the way and did not have the kevlar reinforcement like the front pan. Side by side the MINI won on both accounts. Our Engineers were impressed by the GP2 diffuser design and the front GP2 pan. The one engineer even has a older 911.
https://www.motorauthority.com/news/...works-gp-video
https://www.autoblog.com/news/mini-s...heats-the-wind
Also this was done on the Coupe"
https://libraryofmotoring.info/2011/...es-and-photos/
MINI Coupe wind tunnel images and photos – Library of Motoring
Old Dec 11, 2024 | 01:35 PM
pkgmSu2000's Avatar
pkgmSu2000
I’ve owned 9 cars, all manual trans btw, all non-BMW. All of them had some kind of undertray. I’ve never thought to go looking for one, lol. This is my 1st BMW and I’m regretting it after only 4 weeks. Lol.
Old Dec 11, 2024 | 05:05 PM
bluonyx's Avatar
bluonyx
If you do order the belly pan, don't forget to get the clips also. They aren't installed from the factory. Really annoying when your ready to install and there's nothing for the speed screws to grab on to.
Old Dec 20, 2024 | 01:09 PM
redwhiteR562007's Avatar
redwhiteR562007
I assume you remove the pan or slide it back to change oil?
How long does it take to install?
I saw one reply that said "be sure to order the clips" -- I guess you get those when you get the pan?
Thanks.,
Old Dec 20, 2024 | 02:37 PM
bluonyx's Avatar
bluonyx
Yes, I had ordered #51757330566KT through ECSTuning which is the JCW GP2 Belly Pan Kit. It is supposed to come with hardware and clips for installing but they were missing. Be sure you get them. Install is pretty easy as long as you have enough room under the Mini. I tried to use ramps but I'm to large to slide under with those, so I had to jack up the front end. Popping the clips into the holes was a little tricky but you'll get it.
Old Dec 21, 2024 | 04:44 AM
RedlineR56's Avatar
RedlineR56
One of the first things I did after purchasing my R56 a couple years ago. It has saved my car on several occasions.
Old Dec 21, 2024 | 11:31 AM
pkgmSu2000's Avatar
pkgmSu2000
gorgeous! Maybe some folks will offer used ones in decent condition in 2025
Buffalojim
R57 :: Cabrio Talk (2009+)
Jun 16, 2021 07:57 AM
ihate100bees
Apr 30, 2019 11:53 PM
Cft Shop
Jun 6, 2018 07:11 PM
Bashy85
Mar 21, 2014 08:25 PM
a4autocrossr
Jul 24, 2007 12:56 PM
