R56 Can anyone identify what might be causing a piercing high pitched sound?
Old Apr 1, 2019 | 06:14 PM
lemongrass's Avatar
lemongrass
Please help. I'm presuming I have a bad pully as our 2013 Mini Cooper S makes a high-pitched, piercing sound upon startup in idle. The attached recording was from inside with the doors and windows closed:
http://drive.google.com/file/d/1-9jn...ew?usp=sharing
The sound goes away upon revving the engine.
I used a spectrum analyzer and found the frequency to be 3575Hz. To figure out which pulley is going bad, I need the pulley diameters, the length of the serpentine cable and the crankshaft wheel diameter. I found the following information. Can anybody fill in the information I could not find and might you have any other suggestions?
idle RPM: 800? = 13.33 Hz
serpentine belt length: 904.6mm (not needed. Just ratio of crankshaft diameter to pulley diameters)
idler pully and belt tensioner diameter: 65mm
alternator pulley diameter: 220mm
waterpump pulley diameter: ?
crankshaft "pulley" diameter: ?
I found the serpentine belt diagram here.
Thank you for your help!
Old Apr 4, 2019 | 05:22 PM
lemongrass's Avatar
lemongrass
Bump. I edited and added additional information...
Old Apr 5, 2019 | 05:24 PM
PEneoark's Avatar
PEneoark
Sounds like the climate control blower
Old Apr 8, 2019 | 12:37 AM
lemongrass's Avatar
lemongrass
Thank you for your help, PEneoark.
Old Apr 8, 2019 | 01:00 AM
lemongrass's Avatar
lemongrass
Hi folks,
I've learned from another post that others have experienced this same issue and pulling the dipstick or oil cap stops the noise issue. Apparently it's a whistle from a vacuum. But the post offers no cause or solution:
https://www.northamericanmotoring.co...ch-squeal.html
I also get a rough idle if I pull either. I also lost two quarts of oil and wonder if this somehow caused it?
Does anybody have any insight into this? Might it be a bad PCV?
Thank you!
Old Apr 8, 2019 | 12:03 PM
GyumDoong's Avatar
GyumDoong
Hey, I just went through this like a month ago! You most likely have a torn PCV diaphragm. Is your oil cap really hard to pull when the engine's running?
There's a nice write up from @MrGrumpy here with how to and where to get the parts. It's a pretty easy DIY if you're careful with removing the plastic cap.
https://www.northamericanmotoring.co...-question.html
YouTube video of the issue:
YouTube video of the replacment:
Old Apr 8, 2019 | 01:26 PM
lemongrass's Avatar
lemongrass
Wow! Thank you GyumDoong! Yes, the oil cap is impossible to remove unless you first kill the vacuum by removing the dipstick. I'll give it a go and post my results. Thank you again! Best to you and MrGrumpy too!!!
Old Apr 8, 2019 | 02:06 PM
MrGrumpy's Avatar
MrGrumpy
Yep, the solution from Mini is a new valve cover for $400+. But if it’s only the diaphragm it’s an easy fix. It’s still holding up like new.
MitchV
Dec 20, 2011 07:01 PM
georgia7377
Nov 20, 2009 06:20 AM
donut
May 13, 2004 07:02 PM
fms
Mar 16, 2003 10:48 AM
