R56 R56 2010 Delay Headlights Start
Old Apr 9, 2019 | 05:49 AM
miniuy's Avatar
miniuy
I have "auto-headlights on" activated and a HID kit retrofitted.
My idea is create a delay after ignition (ie: 5s) for the headlights to let the engine start in a clean maner, and that is easy with a delay timer relay.
My question is: there is a way via programming to get this delay as a setting (in FRM, CAS or the module where the setting is)?
Old Apr 9, 2019 | 06:38 AM
Scudder44's Avatar
Scudder44
Not as far as I am aware and I have done a fair bit of coding. I don't see the problem with turning the stalk to put them off until you need them though?
Old Apr 9, 2019 | 07:02 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I would think it would be easier to just turn the switch to "OFF" prior to starting the car...
Old Apr 9, 2019 | 08:00 AM
miniuy's Avatar
miniuy
By law, I need to have headlights always on, even if I don't need it
Old Apr 9, 2019 | 08:15 AM
miniuy's Avatar
miniuy
Yes it's easier but "auto-headlights ON" is more comfortable. The idea is don't care about turning on and off headlights.
In this case (auto-headlights ON) you can't turn it off from the switch (position 0 = headlights ON)
Old Apr 9, 2019 | 08:43 AM
MiniToBe's Avatar
MiniToBe
I assume it should be in the FRM coding. Same logic if you want to turn the fog lights with high beam! or the rear fog lights with reverse. do you have NCS expert and NCS dummy to at least go through the codes?
Alpha Motoring
Dec 20, 2018 07:41 AM
CandorLush
Sep 13, 2015 06:42 PM
fmalgapo
Electrical
17
Jan 20, 2012 12:45 AM
ericmakkar
May 20, 2011 05:16 PM
zemina
Dec 5, 2009 01:44 PM
