R56 Blow of Valve choices
Old Oct 22, 2018 | 10:49 PM
Pramuk's Avatar
Pramuk
I have 2007 Mini Cooper S Fully Mod with stage 3 tuning. I used to have Forge spacer but I had limp mode then I took it off limp mode went away... I am thinking to upgrade BOV my choices Forge, Turbosmart or GFB? which one has good sound or can hold more boost
thanks
Old Oct 24, 2018 | 12:33 PM
oldbrokenwind's Avatar
oldbrokenwind
I'm using TurboSmart, connected as a DV, but I'm also using a big Garrett and it's all external to the turbo. Best results will be using your device as a DV 'cause the ECU monitors all air coming in and flowing thru the engine. If you lose some thru a BOV, you're likely to get a CEL --- unless your tuner can override it. My turboSmart, with a boost controller, can handle 30PSI boost and its sounds are negligible due to other factors.
Old Oct 24, 2018 | 02:08 PM
MrGrumpy's Avatar
MrGrumpy
I use a GFB DV+, it’s not sexy or flashy with cool noises. It’s pretty quiet actually. It sort of sounds like a quick breath, so if you want cool sounds, it’s probably not the one you want. As far as functionality, it’s great, holds all the boost you can throw at it and the ECU retains control. I’m quite happy with it.
Old Oct 24, 2018 | 03:15 PM
E-ROXSPIN's Avatar
E-ROXSPIN
I'm running the DV+ also; However, I am running it with the JMTC S42 Turbo and a DOS Intake.... Sound is Sublime ; Now to get my build out of the shop, and hit the road.
Old Oct 24, 2018 | 03:42 PM
MrGrumpy's Avatar
MrGrumpy
Nice! I have their 40mm turbo, with the factory airbox on the R60 it’s super quiet. I had a cone filter intake on it for a bit, but the factory airbox is better in these. The factory dv makes some nice noise with increased boost, but the DV+ holds noticeably more boost when the transmission shifts. I do get really nice spooling sounds from this turbo though. You can hear it spin up, and it sounds awesome! Lol.
Old Oct 24, 2018 | 09:44 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We run the Forge Recirc valve as it works great and can be adjusted by swapping springs if you up the boost.
https://www.waymotorworks.com/forge-blow-off-valve.html
The spacers are pretty common to throw a light because they vent to atmosphere. Recirculating the boost like the original keeps it off.
Systemlord
May 3, 2019 04:43 PM
ka0tyk
Jan 31, 2018 04:38 PM
kevinminict
Jul 19, 2007 07:44 PM
FortyTwo
Jul 15, 2007 02:56 PM
lovemymini
Sep 1, 2006 08:38 PM
