R56 Disable heated seat bottom cushion only?
Old Jul 11, 2017 | 06:51 AM
harbortime's Avatar
harbortime
Do you guys know of a way I can disable JUST the bottom cushion of the heated seat in my 2013 Coooper S?
Maybe there is a wire that I can cut or unplug?
Any any info would be great!
Old Jul 11, 2017 | 07:09 AM
There is a wire set that goes to the bottom pad and the top back. You would have to trace the one to the bottom pad and bypass it.
https://www.northamericanmotoring.co...-prewired.html
https://www.northamericanmotoring.co...o-2nd-gen.html
I would make a note and if you ever sell the MINI, to reconnect it.
Old Dec 5, 2017 | 06:40 PM
harbortime's Avatar
harbortime
Thanks for the reply!
Unless I take apart my whole seat I won't be able to find the wire that goes to the bottom seat cushion.
Does anyone have a wiring diagram for the R56 LCI heated seats? I need to know what color the wire is that leads to the bottom seat cushion.
Thanks guys!
Old Dec 5, 2017 | 11:38 PM
rkw's Avatar
rkw
https://www.newtis.info/tisv2/a/en/r...-side/EDX15X8g
https://www.newtis.info/tisv2/a/en/r...-side/EDVCIW6J
Looks like the bottom and back are on different connectors to the heating module under the seat.
Old Dec 6, 2017 | 12:00 AM
harbortime's Avatar
harbortime
Fantastic! Thank you so much for taking the time to give back and help people. You're the man!
I unplugged the seat cushion wire and the back wouldn't heat. :\
There must be some sort of system in place that refuses to let just the back part heat without the bottom seat connection. Any thoughts on how to get just the back to heat?
Maybe I could leave the seat cushion pluged in and cut one of the three wires sticking out of it?
Old Dec 6, 2017 | 05:27 AM
Yes, I would disconnect the bottom seat, maybe you disconnected the top by mistake.
Old Dec 6, 2017 | 10:31 AM
MiniToBe's Avatar
MiniToBe
maybe the module is looking for a resistance threshold and removing either changes that setpoint. the module could have disabled itself to prevent fire/burn!
Old Dec 6, 2017 | 10:33 AM
harbortime's Avatar
harbortime
I think this is it. I have unplugged each one respectively and neither work without both plugged in.
I need to find a way around this.
Old Dec 6, 2017 | 10:40 AM
MiniToBe's Avatar
MiniToBe
you can install a resistor instead of the bottom. measure resistance (unplugged) and spec out the resistor for 12V.
if that will be the plan, make sure you secure that resistor in a place or container that withstands head because it will heat up; not sure by how much... do a dry run if it works for few minutes or hours to measure the maximum heat the resistor will exert.
Old Dec 6, 2017 | 10:55 AM
harbortime's Avatar
harbortime
There are three wires in the plug for the bottom seat. 2 for the seat back.
Old Dec 6, 2017 | 10:59 AM
MiniToBe's Avatar
MiniToBe
looking at the wiring diagram, you want to install the resistor (after you find the resistance) across 4 & 1.
Old Dec 6, 2017 | 11:09 AM
DneprDave's Avatar
DneprDave
Why do you want to disable the bottom heater?
Old Dec 6, 2017 | 11:13 AM
harbortime's Avatar
harbortime
Your awesome for helping me. Thanks!
I will give it a try and report back.
Old Dec 6, 2017 | 11:18 AM
harbortime's Avatar
harbortime
I have a bad back and want the seat heater on all the time. I don't want my butt to be hot ALL the time though.
Old Dec 6, 2017 | 11:22 AM
harbortime's Avatar
harbortime
One last question. Do I measure the resistance on the seat heat element or on the box that the heat element plugs into?
I assume it's the 2 wires that connect to the seat element itself but I thought Id ask.
