R56 Aftermarket Swaybar, 19mm or 22mm?
Old Feb 21, 2017 | 08:33 AM
Jckol's Avatar
Jckol
Hey everyone, I am shopping around for a rear swaybar and I cannot decide between the 22mm and the 19mm bars. Because the price difference between the two bars is very small I am tempted to get the 22mm, but I feel like that might cause too much oversteer and make the car more oversteery than the neutral feel I desire. What swaybars are you running on your cars, I am going to be using the car mostly for street use with somewhat frequent autocross events and the occasional trackday. The car has 235/40 tires on it, so with all that extra grip, should I just go with the 22mm?
Old Feb 21, 2017 | 10:03 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
A 22mm wont be over kill for what you'll be doing with your MINI. You could go in between with the Whiteline 20mm bar as it is also 3 point adjustable, which will be perfect for your application and you can adjust it to your feel when you hit the track.
http://www.pelicanparts.com/catalog/..._pg1.htm#item2
888.280.7799 | 6am - 5pm PST
Old Feb 21, 2017 | 10:38 AM
drewstermalloy's Avatar
drewstermalloy
I think a 22mm on the softest setting would be fine for street use. Then you have the option to stiffen it up for autoX.
Old Feb 22, 2017 | 08:23 AM
minirab's Avatar
minirab
I have a 25.5mm hollow bar on the center setting.
Old Feb 22, 2017 | 08:37 AM
TheBigNewt's Avatar
TheBigNewt
19mm, middle setting is enough. I had one on my 2007 and it was great. Way less understeer but still a tiny bit. 22mm watch out for car swapping ends, I remember one guy on this forum who got 23mm and car ended up on its side!
Old Feb 22, 2017 | 09:14 AM
Jckol's Avatar
Jckol
I ordered the 25.5 hsport hollow bar, I plan on running it on the softest setting, if there is too much oversteer I'll just dial the alignment a bit.
Really, the car flipped?? That makes me a little paranoid lol
Old Feb 22, 2017 | 09:24 AM
drewstermalloy
A car wouldn't flip over just because of a sway bar lol.
Old Feb 23, 2017 | 01:14 PM
minirab's Avatar
minirab
The 25.5 hollow bar is the same as a 22 solid bar.
Old Feb 23, 2017 | 07:56 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
He is correct on both. The Hsport Comp bar works just perfect for that car and will be nice and neutral on the middle setting.
https://www.waymotorworks.com/h-spor...-sway-bar.html
Old Feb 23, 2017 | 10:15 PM
Gambedegallina's Avatar
Gambedegallina
Have NM 22 mm solid on both our 2013 R56s and 2016 F56 JCW. great improvement without oversteer on street and track.
Old Feb 23, 2017 | 10:51 PM
renchjeep's Avatar
renchjeep
The Alta 19 adjustable works just fine for me. I started off with the lowest setting, that took care of a lot of the understeer. Recently moved to the middle setting. Car is much more "tossable" now, and I can vary the degree of under/oversteer with the throttle. Rotation is nice and predictable. I may soon go to the tightest setting, just to see what happens. I imagine more tail-happy, which for me is a good thing, as I am used to RWD muscle cars and their handling characteristics.
Old Feb 24, 2017 | 06:33 AM
bugeye1031's Avatar
bugeye1031
Moderator
I have the Whiteline and have it set in the middle. Have done a little bit of track driving and the understeer was dialed back quite a bit.
Old Feb 26, 2017 | 05:24 PM
Jckol's Avatar
Jckol
Got the rear swaybar installed today, put it on the middle setting and WOW what a difference. Car handles like its on rails, not getting any oversteer around corners and a very neutral feeling all around. Probably the best mod I've done to the car yet.
