R56 Turbo oil line question
Old Nov 4, 2016 | 05:30 AM
NB Cooper's Avatar
NB Cooper
I purchased an oil line kit and when it arrived one of the banjo bolts had a built in retrictor (1.5 mm). I thought his to be odd since the OEM system doesn't appear to have any restriction unless it's built into the pressure line.
The seller claims that this is to "Protect" the turbo. I'm hesitant to limit the flow of oil to my turbo so I figured I would ask to see if anyone here had run into this before?
Old Nov 4, 2016 | 09:39 AM
nkfry's Avatar
nkfry
Get OE MINI banjo bolts, the aftermarket ones are cheap and either break on install or leave you with situations as such.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 4, 2016 | 09:42 AM
Euler-Spiral's Avatar
Euler-Spiral
sounds wrong cant you use the stock bolts just new copper washers top and bottom of the fitting, turbos need lots of flow so have a larger return line if the turbos outlet gets clogged it gets hotter and to much pressure can cause leaks at the seal
Old Nov 4, 2016 | 09:49 AM
cerenkov's Avatar
cerenkov
Return the kit and get the one from Detroit Tuned.
Old Nov 4, 2016 | 09:59 AM
NB Cooper's Avatar
NB Cooper
I did use the OEM banjo bolts for all the reasons stated above. I was just wondering if anyone had run into this before.
Old Nov 5, 2016 | 07:36 AM
BigBoost's Avatar
BigBoost
Yeh' get your money back and give the ChadMeister a ring' or just order it on there site' very simple kit' but hands-down the best one you can get !
Old Nov 5, 2016 | 03:33 PM
oldbrokenwind's Avatar
oldbrokenwind
OK, I get confused pretty easily --- this thread started out with an oil line kit and a banjo bolt with a built-in restrictor. The RealOEM diagram for my '07MCS shows banjo bolts on the coolant lines, not oil. Does this kit also have coolant lines?
Old Nov 5, 2016 | 03:49 PM
NB Cooper's Avatar
NB Cooper
My stock MCS has banjo bolts for the oil pressure feed line and on the coolant lines. Not sure why your diagram doesn't show them as they were exactly the same on my 08 MCS as well.
As far as the restrictor goes, nobody had much to say about it except that it didn't make any sense to reduce the flow of oil to the turbo. I agree so I used the stock banjo bolts that don't have any restriction.
Old Nov 5, 2016 | 04:13 PM
oldbrokenwind
OK, I screwed up --- got lazy and made a bad assumption, without looking at all diagrams. There's three banjo bolts on the OEM turbo --- two coolant one oil.
After blowing out my Garrett bearings, I wouldn't restrict oil flow either --- Garrett doesn't use banjo bolts on oil lines, just coolant.
Old Nov 9, 2016 | 06:37 AM
danraabe's Avatar
danraabe
Oil line
[QUOTE=oldbrokenwind;4255767]OK, I get confused pretty easily --- this thread started out with an oil line kit and a banjo bolt with a built-in restrictor. The RealOEM diagram for my '07MCS shows banjo bolts on the coolant...
Get the proper line from JM turbocoopers. Arric will wrap it with heat shielding and you will be in good shape
Old Nov 22, 2018 | 08:43 AM
NB Cooper's Avatar
NB Cooper
Well flash forward a few years and here I am with a completely different Mini dealing with the same old issues. Once again my oil feed kit has arrived with a restrictor built into the banjo bolt. I have installed it but I haven't driven far yet as I'm dealing with all the other fun stuff like thermostat housings, broken exhaust flex joint, leaky oil filter housing, valve carbon, timing chain and ABS. It's easily changed back without any component removal.
So I've been doing some homework on the subject and I have discovered that the restrictor is something that is typically used on ball bearing turbos but not on our stock K03 journal (bushing) type turbos, where oil flow is your friend, to keep the center housing as cool as possible. So there ya go, a good reason to not use that restrictor on a stock Mini but also a good reason why one is used on the ball bearing upgraded units.
Old Nov 24, 2018 | 10:59 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
It should not have a restriction in the bolt. MINI doesn't use one from the factory https://www.detroittuned.com/dt-turb...ine-super-kit/ .
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
