R56 Exhaust Smoke
Old Aug 12, 2016 | 01:43 PM
EMKFLYER's Avatar
EMKFLYER
Exhaust Smoke
Hello, I have a 2009 Cooper JCW with 74,000 miles. I have noticed some blueish some from the exhaust after the car is warm and sitting at idle.
The compression test showed the following: Cylinders 3&4 were 140 PSI. Cylinders 1&2 were 145 PSI. A wet test was then conducted (small amount of oil poured into each cylinder): All cylinders increased by 5 PSI
A leak down test was then conducted. All cylinders were less than 3%.
Finally, a Crank Case Pressure Test was completed. The difference between atmospheric pressure and crank case pressure was 0.0408 or 40.8 millibars.
Can anyone point me in the right direction on what this means and what I can do to to fix the exhaust smoke?
Thank you
Ed
Old Aug 12, 2016 | 07:37 PM
Shteve's Avatar
Shteve
Thank you
Ed
My 2010 MCS had the same symptoms. Puff Of blue smoke at start up and blue smoke when giving it a quick rev after the car got up to temp (after idling 1+ minutes). Turned out to be piston rings were letting in a lot of oil into cylinder #4. My car had 55 000 miles.
Old Aug 12, 2016 | 07:52 PM
EMKFLYER's Avatar
EMKFLYER
Did you use any oil additives or did you replace the rings?
Ed
Old Aug 12, 2016 | 11:33 PM
Shteve's Avatar
Shteve
Ed
My car had extended warranty from MINI. After they made sure it wasn't the valve cover causing the issue, the dealer just replaced the entire engine.
eliseo1981
May 2, 2016 06:44 PM
lukgar1
Apr 25, 2016 01:19 PM
lasher10
Apr 23, 2016 12:41 PM
thelawson
Mar 29, 2016 09:45 AM
VerucaSalt
40
Nov 10, 2005 11:50 AM
